[Ground-station] GMAT vs. STK/HPOP - call for help
Juno Woods
juno at openlunar.org
Tue Feb 9 10:30:20 PST 2021
HEO as in highly elliptical or high earth orbit?
On Mon, Feb 8, 2021 at 2:36 PM Michelle Thompson <
> Greetings Juno!
> The orbit that Jan was most interested in is a HEO orbit, perigee at
> 1250km. The concern was over some results he was getting with the SMAD
> spreadsheet and a relatively lightweight satellite.
> There's another set of work that Anshul Makkar is doing that shows GTO to
> Graveyard, but that so far doesn't have anything unexpected that we were
> looking to run by people with more experience and additional software.
> On Fri, Feb 5, 2021 at 12:30 PM Juno Woods <juno at openlunar.org> wrote:
>> Can you say more about the parameters? Is the satellite inserted into LEO
>> or GTO or some other orbit? Is phasing needed?
>> On Fri, Jan 29, 2021 at 5:29 PM Michelle Thompson via Ground-Station
>>> For the Debris Mitigation presentation to the FCC, we want to give
>>> answers (and show our work) about how much delta-v we need for some of the
>>> proposed orbits for minimum viable amateur spacecraft in the Amateur Radio
>>> Satellite Service.
>>> There's a question that Jan King and I have about a critical altitude
>>> and low surface_area:mass ratio spacecraft. It occurred to us that we
>>> really might want to compare results across two or more software packages
>>> to build some confidence.
>>> Jan has a set of results from a spreadsheet from SMAD.
>>> https://smad.com/
>>> The calculation under review is around 165km with a relatively
>>> lightweight 6U spacecraft. It's acting like it wants to do some strange
>>> things. Is this physics, or at a limit of the model?
>>> We have a couple of people who are good or are getting good at GMAT.
>>> https://software.nasa.gov/software/GSC-17177-1
>>> Question: Are the atmospheric models in GMAT good enough for this
>>> calculation?
>>> Does anyone have access to STK/HPOP to run this calculation, for
>>> comparison?
>>> https://www.agi.com/products/stk
>>> https://help.agi.com/stk/11.0.1/Content/hpop/hpop.htm
>>> Thank you,
>>> -Michelle W5NYV
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20210209/edd53bd0/attachment.html>
