Mon Mar 23 14:12:55 PDT 2020
Stratospheric... atmospheric... ionospheric... anodes... cathodes...
electrodes... overloads.... generators.... oscillators....
it all starts to run together. :+)
This technique is good to know in case we need to bring it to heel.
I'm not afraid of the work. We just need to know what must be done.
On Mon, Mar 23, 2020 at 2:02 PM KENT BRITAIN <wa5vjb at flash.net> wrote:
> Woops, the speal cheeker program got me. Atmospheric Bending
> On Monday, March 23, 2020, 4:00:46 PM CDT, KENT BRITAIN via Ground-Station
> Good info, I have seen 1.5 deg difference between the Calculated/Optical
> position of
> the moon and the Radio moon. The problem is stratospheric bending.
> I once asked Tom W3IWI how they dealt with this on the big dishes.
> "We track 4 Quasars Horizon to Horizon then do lease squares best fit.
> Our tracking programs also allow for Barometric Pressure, Air Temp, and
> Humidity"
> For a 6 footer, this bending should be a non issue above 40 deg or so.
> Kent
> On Monday, March 23, 2020, 3:51:30 PM CDT, Michelle Thompson <
> We baseline a 2m dish for the JAMSAT/ORI effort.
> I assume this will be about 45dB of gain with the usual dish efficiency
> losses, and will give a 1 degree 3dB beamwidth.
> On Mon, Mar 23, 2020 at 1:17 PM KENT BRITAIN via Ground-Station
> Back to my original question, what gain are you designing around for the
> ground station antenna?
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200323/e15430f5/attachment.html>
