Mon Mar 23 14:21:22 PDT 2020
A simple look-up table in the elevation calculation should do it.
For 0-10 deg Assume the moon is 1 deg lower than it really is.
For 10-40 deg Assume the moon is .5 deg lower than it really is.
40+ deg Use the calculated position.
Errors should be within the normal beamwidth unless you live at a
very high elevation.
On Monday, March 23, 2020, 4:13:34 PM CDT, Michelle Thompson <mountain.michelle at gmail.com> wrote:
Stratospheric... atmospheric... ionospheric... anodes... cathodes... electrodes... overloads.... generators.... oscillators....
it all starts to run together. :+)
This technique is good to know in case we need to bring it to heel.
I'm not afraid of the work. We just need to know what must be done.
On Mon, Mar 23, 2020 at 2:02 PM KENT BRITAIN <wa5vjb at flash.net> wrote:
Woops, the speal cheeker program got me. Atmospheric Bending
On Monday, March 23, 2020, 4:00:46 PM CDT, KENT BRITAIN via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Good info, I have seen 1.5 deg difference between the Calculated/Optical position ofthe moon and the Radio moon. The problem is stratospheric bending.I once asked Tom W3IWI how they dealt with this on the big dishes."We track 4 Quasars Horizon to Horizon then do lease squares best fit. Our tracking programs also allow for Barometric Pressure, Air Temp, and Humidity"
For a 6 footer, this bending should be a non issue above 40 deg or so.
Kent
On Monday, March 23, 2020, 3:51:30 PM CDT, Michelle Thompson <mountain.michelle at gmail.com> wrote:
We baseline a 2m dish for the JAMSAT/ORI effort.
I assume this will be about 45dB of gain with the usual dish efficiency losses, and will give a 1 degree 3dB beamwidth.
On Mon, Mar 23, 2020 at 1:17 PM KENT BRITAIN via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Back to my original question, what gain are you designing around for theground station antenna?
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200323/56de6ea0/attachment.html>
