Mon Mar 23 14:02:54 PDT 2020
Woops, the speal cheeker program got me. Atmospheric Bending
On Monday, March 23, 2020, 4:00:46 PM CDT, KENT BRITAIN via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Good info, I have seen 1.5 deg difference between the Calculated/Optical position ofthe moon and the Radio moon. The problem is stratospheric bending.I once asked Tom W3IWI how they dealt with this on the big dishes."We track 4 Quasars Horizon to Horizon then do lease squares best fit. Our tracking programs also allow for Barometric Pressure, Air Temp, and Humidity"
For a 6 footer, this bending should be a non issue above 40 deg or so.
Kent
On Monday, March 23, 2020, 3:51:30 PM CDT, Michelle Thompson <mountain.michelle at gmail.com> wrote:
We baseline a 2m dish for the JAMSAT/ORI effort.
I assume this will be about 45dB of gain with the usual dish efficiency losses, and will give a 1 degree 3dB beamwidth.
On Mon, Mar 23, 2020 at 1:17 PM KENT BRITAIN via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Back to my original question, what gain are you designing around for theground station antenna?
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200323/e19bb1ac/attachment.html>
