Ron Economos
w6rz at comcast.net
Mon Sep 30 15:12:03 PDT 2019
What magnitude of Doppler shift would be expected at 10.4 GHz? Total
shift, and more importantly, rate of shift.
I've done some preliminary testing with a DVB-S2 receiver, and it can
handle 30 kHz/second no problem.
On 9/29/19 09:32, Leffke, Zachary via Ground-Station wrote:
> Carrier/Beacon at 10G? atmega328 to handle CW IDing every so often? Obviously less operational ground stations, but might encourage the construction of 10G ground stations (Ku PLL LNB, bias-t, FCDPP or RTLSDR), which fuels the five/dime drive. Baby steps toward 10G amateur satellite spectrum use? Doppler at 10G from LEO should be fun. Antenna would be compact, maybe a patch on one side of a 4-layer board and components on the other....room for the solar cells?
> This looks like the big brother of the Kicksats.....hardest part looks like power from the solar cells....2.2V @ 80mA according to their website. They do specifically say in their FAQs that you can't add another radio.....but sounds like they could be convinced.
> Good stuff. I'd be interested in ANY beacon on ANY band, Doppler is fun.
> -Zach, KJ4QLP
