[Ground-station] Ground-Station Digest, Vol 18, Issue 16
Tue Oct 1 13:00:57 PDT 2019
Thank you so much Thomas. I enthusiastically take you up on the offer!
Wally Ritchie and others are working hard on the detailed proposal
documents for the payload, but a system level definition should not clash
with that. We all welcome your experience and enthusiasm. I'll make sure
you're added to the repository if you are not already.
On Tue, Oct 1, 2019 at 11:01 AM Thomas Parry via Ground-Station
> I fully agree with your point 2. What is the best way to progress the
> space segment, start pulling together a system level definition on the
> github space repository?
> I have experience doing satellite design at a top nanosatellite
> manufacturer plus ESA project tech R&D at the IC design level so I can hit
> the ground running but also don't want to clash with other work you may
> have done.
> Cheers,
> Thomas
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191001/9cd20178/attachment.html>
