[Ground-station] Upcoming channelizer test opportunity
Mike Seguin
Wed Jun 26 04:29:16 PDT 2019
Hi Michelle,
Could I get a bit more explanation of what you want to test?
The North East Weak Signal Group (NEWS) gets together in a few weeks
(7/13) for our annual picnic and MDS/ERP testing. This year we will test
10/24/47 GHz. In the past we'd also test 78 GHz, but we found we run out
of time!
We have quite a group of stations that get together. Pic from 2016 of
the 47 GHz testing attached. We had seven stations that year on 47 GHz.
It keeps getting bigger.
Mike
On 6/26/2019 6:57 AM, Michelle Thompson via Ground-Station wrote:
> Later in the summer we usually have at least one tuning party for the
> 2GHz and Up amateur radio contest. That would be a good opportunity to
> try on air testing with this channelizer at microwave.
> The way the test works is there is a transceiver just outside of near
> field range. Minimum discernible signal and output gain are the two
> numbers obtained. For the test it’s usually done serially, everyone
> using same frequency, one at a time.
> Channelizer wouldn’t replace that setup, but the event has lots of
> radios all in one place on all kinds of amateur Microwave bands so we
> should try and take advantage of it, assuming the channelizer will
> reliably work by then, and that we can put an SDR up on a pole and at
> least receive with it. 5GHz and 10GHz are straightforward. Above that,
> we need more RF RX gear.
> There is another similar event up in Los Angeles, around the same time.
> So, if you have a local Microwave Group that does something similar, and
> want to test a channelizer, let me know. At the very least would be a
> fun paper for Microwave Update or GNU Radio Conference. And, an
> effective amateur radio demo of polyphase channelizers in practice.
> -mdt
Mike, N1JEZ
Name: seven_stations_47_GHz Cleaned.JPG
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190626/21d0484e/attachment.jpe>
