[Ground-station] Initial DVB-S2 Rx Data Stream Explorations
Ron Economos
w6rz at comcast.net
Thu Feb 28 06:10:31 PST 2019
For the DVB-GSE baseband, you would just use Wireshark since the output
of the receiver is IP packets. If you have a receiver that can output
the raw baseband frames, there is a DVB-GSE dissector in Wireshark.
For a Transport Stream baseband, you would just play the stream with a
media player like VLC.
For layers below the baseband, there's nothing.
On 2/28/19 04:58, Stan, W1LE via Ground-Station wrote:
> Hello The Net:
> I am starting to think about the DVB-S2X Rx data stream and was
> wondering if there is software for a Windows or Linux PC
> to look at the details of the data stream. Something similar to
> Wireshark for Ethernet or WiFi?
> Stan, W1LE Cape Cod FN41sr
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190228/33efa3de/attachment.html>
