[Ground-station] Initial DVB-S2 Rx Data Stream Explorations
Stan, W1LE
stanw1le at verizon.net
Thu Feb 28 06:35:25 PST 2019
Ron,
Thanks for your comments. That gets me started.
Stan, W1LE
On 2/28/2019 9:10 AM, Ron Economos via Ground-Station wrote:
> For the DVB-GSE baseband, you would just use Wireshark since the
> output of the receiver is IP packets. If you have a receiver that can
> output the raw baseband frames, there is a DVB-GSE dissector in Wireshark.
> For a Transport Stream baseband, you would just play the stream with a
> media player like VLC.
> For layers below the baseband, there's nothing.
> Ron W6RZ
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190228/eb3fd49e/attachment.html>
