[Ground-station] DVB Monitoring, was: Need advice on DVB-S2 modem
Charles Brain
chbrain at btinternet.com
Mon Dec 9 13:24:17 PST 2019
You can run the LongMynd receiver software with the DATV-Express Minitiouner
you should be able to see whatever you need with that.
https://github.com/myorangedragon/longmynd
- Charles
On 09/12/2019 21:05, Art Towslee wrote:
> Stan,
> I can't accurately answer because Charles Brain G4GUO did all
> software. I don't know what the Wireshark dissectors are. I DO know
> that it is easy to record a snapshot of the received transport stream
> and view the computer data with standard analyzers. We provide a
> "record" feature where pressing the button will store the continuous
> transport stream until the button is again pressed. The receiver does
> have an internal 8 bit parallel transport stream but it is not wired
> out. It goes directly to the USB controller chip.
> The associated free MiniTioune software we provide with the
> MiniTioune-Express receiver has a lot of diagnostic features including
> a constellation display. *Charles, can you elaborate on this?*
> Art.
> On 12/9/2019 12:55 PM, Stan, W1LE via Ground-Station wrote:
>> Hello Art and the Net:
>> any idea if the DATV-Express receiver can have a output tap to look
>> at the data stream output with the Wireshark dissectors ?
>> My objective is to look at the DVB satellite downlink data stream to
>> better understand what is going on and to monitor my locally
>> generated DVB datastream, as I modify the various parameters.
>> If the DATV-Express receiver does not have a data stream output, any
>> suggestions on a receiver that does provide a suitable data stream
>> output?
>> Thanks Stan, W1LE Cape Cod
>> On 12/9/2019 9:52 AM, Art Towslee via Ground-Station wrote:
>>> Mike,
>>> In regard to your need for a receiver that will demodulate signals <
>>> 200Ksymbols, The DATV-Express group makes a tuner/receiver that will
>>> receive a DVB-S/S2 signal as low as 70Ksymbols/sec on a frequency of
>>> 144 to 2420MHz. I designed the hardware part of it and sell it for
>>> $75 + shipping. Check out the specs at www.DATV-Express.com. Let me
>>> know if I can help.
>>> Regards,
>>> Art Towslee
>>> WA8RMC
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/caa5ce34/attachment.html>
