[Ground-station] DVB Monitoring, was: Need advice on DVB-S2 modem
Mon Dec 9 13:18:49 PST 2019
Wireshark is the most popular and widely used network packet analyzer. GSE
packets, and many other types of packetized data, can be analyzed using
Wireshark.
I believe the record feature captures raw data, which then can be usefully
analyzed by a variety of tools.
On Mon, Dec 9, 2019 at 1:09 PM Art Towslee via Ground-Station
> Stan,
> I can't accurately answer because Charles Brain G4GUO did all software. I
> don't know what the Wireshark dissectors are. I DO know that it is easy to
> record a snapshot of the received transport stream and view the computer
> data with standard analyzers. We provide a "record" feature where pressing
> the button will store the continuous transport stream until the button is
> again pressed. The receiver does have an internal 8 bit parallel transport
> stream but it is not wired out. It goes directly to the USB controller chip.
> The associated free MiniTioune software we provide with the
> MiniTioune-Express receiver has a lot of diagnostic features including a
> constellation display. *Charles, can you elaborate on this?*
> Art.
> On 12/9/2019 12:55 PM, Stan, W1LE via Ground-Station wrote:
> Hello Art and the Net:
> any idea if the DATV-Express receiver can have a output tap to look at the
> data stream output with the Wireshark dissectors ?
> My objective is to look at the DVB satellite downlink data stream to
> better understand what is going on and to monitor my locally generated DVB
> datastream, as I modify the various parameters.
> If the DATV-Express receiver does not have a data stream output, any
> suggestions on a receiver that does provide a suitable data stream output?
> Thanks Stan, W1LE Cape Cod
> On 12/9/2019 9:52 AM, Art Towslee via Ground-Station wrote:
> Mike,
> In regard to your need for a receiver that will demodulate signals <
> 200Ksymbols, The DATV-Express group makes a tuner/receiver that will
> receive a DVB-S/S2 signal as low as 70Ksymbols/sec on a frequency of 144 to
> 2420MHz. I designed the hardware part of it and sell it for $75 + shipping.
> Check out the specs at www.DATV-Express.com. Let me know if I can help.
> Regards,
> Art Towslee
> WA8RMC
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/0e2eb86a/attachment.html>
