[Ground-station] DVB Monitoring, was: Need advice on DVB-S2 modem
Art Towslee
towslee1 at ee.net
Mon Dec 9 13:05:55 PST 2019
Stan,
I can't accurately answer because Charles Brain G4GUO did all software.
I don't know what the Wireshark dissectors are. I DO know that it is
easy to record a snapshot of the received transport stream and view the
computer data with standard analyzers. We provide a "record" feature
where pressing the button will store the continuous transport stream
until the button is again pressed. The receiver does have an internal 8
bit parallel transport stream but it is not wired out. It goes directly
to the USB controller chip.
The associated free MiniTioune software we provide with the
MiniTioune-Express receiver has a lot of diagnostic features including a
constellation display. *Charles, can you elaborate on this?*
Art.
On 12/9/2019 12:55 PM, Stan, W1LE via Ground-Station wrote:
> Hello Art and the Net:
> any idea if the DATV-Express receiver can have a output tap to look at
> the data stream output with the Wireshark dissectors ?
> My objective is to look at the DVB satellite downlink data stream to
> better understand what is going on and to monitor my locally generated
> DVB datastream, as I modify the various parameters.
> If the DATV-Express receiver does not have a data stream output, any
> suggestions on a receiver that does provide a suitable data stream output?
> Thanks Stan, W1LE Cape Cod
> On 12/9/2019 9:52 AM, Art Towslee via Ground-Station wrote:
>> Mike,
>> In regard to your need for a receiver that will demodulate signals <
>> 200Ksymbols, The DATV-Express group makes a tuner/receiver that will
>> receive a DVB-S/S2 signal as low as 70Ksymbols/sec on a frequency of
>> 144 to 2420MHz. I designed the hardware part of it and sell it for
>> $75 + shipping. Check out the specs at www.DATV-Express.com. Let me
>> know if I can help.
>> Regards,
>> Art Towslee
>> WA8RMC
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/8406080b/attachment.html>
