[Ground-station] DVB Monitoring, was: Need advice on DVB-S2 modem
Stan, W1LE
stanw1le at verizon.net
Mon Dec 9 09:55:47 PST 2019
Hello Art and the Net:
any idea if the DATV-Express receiver can have a output tap to look at
the data stream output with the Wireshark dissectors ?
My objective is to look at the DVB satellite downlink data stream to
better understand what is going on and to monitor my locally generated
DVB datastream, as I modify the various parameters.
If the DATV-Express receiver does not have a data stream output, any
suggestions on a receiver that does provide a suitable data stream output?
Thanks Stan, W1LE Cape Cod
On 12/9/2019 9:52 AM, Art Towslee via Ground-Station wrote:
> Mike,
> In regard to your need for a receiver that will demodulate signals <
> 200Ksymbols, The DATV-Express group makes a tuner/receiver that will
> receive a DVB-S/S2 signal as low as 70Ksymbols/sec on a frequency of
> 144 to 2420MHz. I designed the hardware part of it and sell it for $75
> + shipping. Check out the specs at www.DATV-Express.com. Let me know
> if I can help.
> Regards,
> Art Towslee
> WA8RMC
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/816ebd51/attachment.html>
