[Ground-station] Need advice on DVB-S2 modem
Art Towslee
towslee1 at ee.net
Mon Dec 9 06:52:24 PST 2019
Mike,
In regard to your need for a receiver that will demodulate signals <
200Ksymbols, The DATV-Express group makes a tuner/receiver that will
receive a DVB-S/S2 signal as low as 70Ksymbols/sec on a frequency of 144
to 2420MHz. I designed the hardware part of it and sell it for $75 +
shipping. Check out the specs at www.DATV-Express.com. Let me know if I
can help.
Regards,
Art Towslee
WA8RMC
On 12/8/2019 8:05 PM, Mike Parker via Ground-Station wrote:
> A team headed by the University of Arizona is working on a 6-U
> satellite that will fly at 500 km altitude. The satellite, named
> CatSat after the UofA wildcat mascot, was described in a paper
> presented at the Amsat Annual Meeting. We are shooting for a launch
> that could be as early as one year from now. The plan is to have a
> downlink using DVB-S2 modulation generated by an FPGA on the AstroSDR
> card provided by Rincon Research. This modulation was chosen so that
> hams that have been working phase4 ground DVB-S2X might receive and
> demodulate the link. We are planning to transmit a limited number of
> ModCod’s. Modcod 7, QPSK 3/4, and modcod 17, 8-PSK 9/10 are likely
> choices.
> Two experiments plan to use DVB-S2 modulation on the downlink. One
> involves transmitting high quality video, and the other will capture
> and retransmit narrowband pieces of the HF ham bands containing WSPR
> and FT8 signals. Closing the link to our 6.1 meter diameter ground
> station is no problem, and we are planning on a modulation bandwidth
> up to 20 MHz and bit rates over 50 Mbps when using the satellite’s
> inflatable directive antenna provided by FreeFall. But closing the
> link to a ham 0.6 meter dish when operating with an onmi-directional
> transmit antenna poses a very different problem. We will likely
> require small downlink bandwidths on the order of 200 kHz.
> We are looking for a demodulator to assist in testing the satellite,
> and also a demodulator for use in the ground station. So we are
> reaching out to you for suggestions. We hope that an available
> commercially for an affordable price, or perhaps something designed by
> a member of this group. We have neither the desire or time to
> reinvent the wheel.
> Several things concern us we would appreciate advice on.
> 1) We read with interest a paper by Downey, Evans, and Tollis, “DVB-S2
> Experiment over NASA’s Space Network”. It said “ typical commercial
> DVB-S2 receivers are not designed for symbol rates below 300 kbaud”.
> That is consistent with our observation that many commercial
> demodulators do not seem to have a lowest bandwidth specification.
> Anyone know of one that goes lower in bandwidth while having a high
> bandwidth capability?
> 2) We need to have a demodulator that will output raw DVB-S2 frames,
> bypassing any transport layer protocols which are normally used with
> DVB-s2 such as Multi-protocol Encapsulation(MPE) or Geeric Stream
> Encapsulation (GSE). Downey, Evans, and Tollis used a Newtec MDM6000
> modem. Is there a better or cheaper solution? (I haven’t priced one
> yet).
> 3) Doppler shifts are also a concern, especially at a low data rate,
> but we have a plan to solve that if necessary using a local oscillator
> in the ground station that is swept according to ephemeris predictions
> to de-Doppler the signal before demodulation.
> Oh yes, some good news. The first of our 6.1 meter dishes has been
> reassembled in Rincon’s parking lot in Centennial, CO. A picture with
> assembly in progress is attached. I’m flying up tomorrow with a 10
> GHz feed horn and LNA to see if we can hear signals!
> Mike Parker, KT7D
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/f4351b35/attachment.html>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/f4351b35/attachment.jpg>
