[Ground-station] Need advice on DVB-S2 modem
Ron Economos
w6rz at comcast.net
Mon Dec 9 07:07:13 PST 2019
I've been using the Digital Devices Max SX8.
https://www.digital-devices.eu/shop/en/tv-cards/tv-cards-for-pcie/340/8-tuner-tv-card-dd-max-sx8-4/8-dvb-s2/dvb-s2x-full-spectrum?c=156
It can go down to 100 kSyms/s and can output raw bbframes. It's also
very tolerant to Doppler shift (capable of 30 kHz/s at 10 Msyms/s) . At
high bandwidths, you probably won't need LO sweeping.
It's supported in the Linux kernel starting at release 4.20. Plug and
play on Ubuntu.
It can also output raw IQ and demodulator IQ. Here's a video showing
demodulator IQ.
http://www.w6rz.net/sx8.mp4
It's a little pricey at 500 Euros.
On 12/8/19 17:05, Mike Parker via Ground-Station wrote:
> A team headed by the University of Arizona is working on a 6-U
> satellite that will fly at 500 km altitude. The satellite, named
> CatSat after the UofA wildcat mascot, was described in a paper
> presented at the Amsat Annual Meeting. We are shooting for a launch
> that could be as early as one year from now. The plan is to have a
> downlink using DVB-S2 modulation generated by an FPGA on the AstroSDR
> card provided by Rincon Research. This modulation was chosen so that
> hams that have been working phase4 ground DVB-S2X might receive and
> demodulate the link. We are planning to transmit a limited number of
> ModCod’s. Modcod 7, QPSK 3/4, and modcod 17, 8-PSK 9/10 are likely
> choices.
> Two experiments plan to use DVB-S2 modulation on the downlink. One
> involves transmitting high quality video, and the other will capture
> and retransmit narrowband pieces of the HF ham bands containing WSPR
> and FT8 signals. Closing the link to our 6.1 meter diameter ground
> station is no problem, and we are planning on a modulation bandwidth
> up to 20 MHz and bit rates over 50 Mbps when using the satellite’s
> inflatable directive antenna provided by FreeFall. But closing the
> link to a ham 0.6 meter dish when operating with an onmi-directional
> transmit antenna poses a very different problem. We will likely
> require small downlink bandwidths on the order of 200 kHz.
> We are looking for a demodulator to assist in testing the satellite,
> and also a demodulator for use in the ground station. So we are
> reaching out to you for suggestions. We hope that an available
> commercially for an affordable price, or perhaps something designed by
> a member of this group. We have neither the desire or time to
> reinvent the wheel.
> Several things concern us we would appreciate advice on.
> 1) We read with interest a paper by Downey, Evans, and Tollis, “DVB-S2
> Experiment over NASA’s Space Network”. It said “ typical commercial
> DVB-S2 receivers are not designed for symbol rates below 300 kbaud”.
> That is consistent with our observation that many commercial
> demodulators do not seem to have a lowest bandwidth specification.
> Anyone know of one that goes lower in bandwidth while having a high
> bandwidth capability?
> 2) We need to have a demodulator that will output raw DVB-S2 frames,
> bypassing any transport layer protocols which are normally used with
> DVB-s2 such as Multi-protocol Encapsulation(MPE) or Geeric Stream
> Encapsulation (GSE). Downey, Evans, and Tollis used a Newtec MDM6000
> modem. Is there a better or cheaper solution? (I haven’t priced one
> yet).
> 3) Doppler shifts are also a concern, especially at a low data rate,
> but we have a plan to solve that if necessary using a local oscillator
> in the ground station that is swept according to ephemeris predictions
> to de-Doppler the signal before demodulation.
> Oh yes, some good news. The first of our 6.1 meter dishes has been
> reassembled in Rincon’s parking lot in Centennial, CO. A picture with
> assembly in progress is attached. I’m flying up tomorrow with a 10
> GHz feed horn and LNA to see if we can hear signals!
> Mike Parker, KT7D
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/98e1a468/attachment.html>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191209/98e1a468/attachment.jpg>
