[Ground-station] Now that we've heard some good news... LDPC block work needed - LDPC team alert
Ahmet Inan
xdsopl at gmail.com
Wed Oct 24 05:23:23 PDT 2018
Yeah, I did the math last night to get soft information from BPSK,
QPSK and 8PSK modulation and it would be nice if someone could look
over it.
I am not entirely sure if I got the SNR stuff right but it works very well.
Also, please beware that my 8PSK is Pi/8 rotated.
I put the new PSK stuff into the psk branch in order not to disturb
the others using the master tree:
https://github.com/xdsopl/LDPC/tree/psk
Ahmet
On Wed, Oct 24, 2018 at 1:32 PM Michelle Thompson
> Thank you Ahmet.
> I believe your next goal is performance improvements with PSK?
> Is there anything that we can do to help out with this part?
> -mdt
> On Tue, Oct 23, 2018, 23:30 Ahmet Inan <xdsopl at gmail.com> wrote:
>> Just fixed the few issues regarding g++ compatibility.
>> You can switch between clang++ and g++ in the Makefile.
>> Ahmet
>> On Wed, Oct 24, 2018 at 8:17 AM Michelle Thompson via Ground-Station
>> > Ron reports that the Clang dependency is problematic. A conversion to gcc will/should be discussed.
>> > On Tue, Oct 23, 2018, 14:25 Michelle Thompson <mountain.michelle at gmail.com> wrote:
>> >> We heard some good news yesterday.
>> >> But there is bad news!
>> >> The bad news is that we aren't done yet, and have plenty to do!
>> >> I'm working on getting the DVB-S2/X code donation from Aerospace Corporation (offered at the GRCon18 Block Party) into the code base of GNU Radio. In the meantime, we have a recently published open source LDPC repository that we should look at, right now.
>> >> This is written by Ahmet Inan, Co-founder & CEO aicodix GmbH. They are located in Germany and is on our Slack.
>> >> Recent bugs in this codebase have been sorted out. Can we get this into a GNU Radio block and tested ASAP?
>> >> There is at least one other potential code base from a local LDPC expert, but it needs some work before release.
>> >> Can we get something ready for review by this weekend?
>> >> -Michelle W5NYV
>> > _______________________________________________
>> > Ground-Station mailing list
>> > Ground-Station at lists.openresearch.institute
>> > http://lists.openresearch.institute/mailman/listinfo/ground-station
>> Ahmet Inan
>> Co-founder and CEO of aicodix GmbH
>> https://www.aicodix.de/
Ahmet Inan
