[Ground-station] Now that we've heard some good news... LDPC block work needed - LDPC team alert
Wed Oct 24 04:32:37 PDT 2018
Thank you Ahmet.
I believe your next goal is performance improvements with PSK?
Is there anything that we can do to help out with this part?
-mdt
On Tue, Oct 23, 2018, 23:30 Ahmet Inan <xdsopl at gmail.com> wrote:
> Just fixed the few issues regarding g++ compatibility.
> You can switch between clang++ and g++ in the Makefile.
> Ahmet
> On Wed, Oct 24, 2018 at 8:17 AM Michelle Thompson via Ground-Station
> > Ron reports that the Clang dependency is problematic. A conversion to
> gcc will/should be discussed.
> > On Tue, Oct 23, 2018, 14:25 Michelle Thompson <
> >> We heard some good news yesterday.
> >> But there is bad news!
> >> The bad news is that we aren't done yet, and have plenty to do!
> >> I'm working on getting the DVB-S2/X code donation from Aerospace
> Corporation (offered at the GRCon18 Block Party) into the code base of GNU
> Radio. In the meantime, we have a recently published open source LDPC
> repository that we should look at, right now.
> >> https://github.com/xdsopl/LDPC
> >> This is written by Ahmet Inan, Co-founder & CEO aicodix GmbH. They are
> located in Germany and is on our Slack.
> >> Recent bugs in this codebase have been sorted out. Can we get this into
> a GNU Radio block and tested ASAP?
> >> There is at least one other potential code base from a local LDPC
> expert, but it needs some work before release.
> >> Can we get something ready for review by this weekend?
> >> -Michelle W5NYV
> > _______________________________________________
> > Ground-Station mailing list
> > Ground-Station at lists.openresearch.institute
> > http://lists.openresearch.institute/mailman/listinfo/ground-station
> Ahmet Inan
> Co-founder and CEO of aicodix GmbH
> https://www.aicodix.de/
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20181024/e4485c02/attachment.html>
