Tue Jun 19 16:58:49 PDT 2018
Same results here with building. Good idea on the issue filing.
On Tue, Jun 19, 2018 at 4:37 PM, Jan Schiefer <jan at akalaitis.net> wrote:
> Hi Steve,
> Can you please file an issue in the GitHub repo, so others are aware of
> the problem and can do something about it if they wish?
> This is also helps us practice handling contributions from the community
> in an efficient manner.
> Thanks,
> Jan, ac7td
> On Jun 19, 2018 12:39 PM, Steve Conklin via Ground-Station
> > I had a go at building it on Ubuntu 16.04 (Xenial). I needed the more
> recent fftw version but building and installing the tarball as directed in
> the 'dependencies' file failed to resolve the issue.
> > The exact failure is an implicit declaration
> of fftwf_make_planner_thread_safe(), presumably because the right library
> version headers are not in place.
> > I don't have more time to look at this at the moment but I'll get back
> to it eventually.
> > On Mon, Jun 18, 2018 at 10:56 AM, Michelle Thompson via Ground-Station
> >> KA9Q SDR repository has been updated with the help of Jan Shiefer.
> >> https://github.com/phase4ground/ka9q-sdr
> >> There is a lot of great code in here. Leveraging IP Multicast and the
> method of providing metadata for IQ samples are two big concepts that we
> should talk a lot more about.
> >> We've been asked to write a paper about it, so I've started working
> specifically on that with Phil to make it as easy as possible to get a
> clear description of the advantages and innovations.
> >> -Michelle W5NYV
> >> _______________________________________________
> >> Ground-Station mailing list
> >> Ground-Station at lists.openresearch.institute
> >> http://lists.openresearch.institute/mailman/listinfo/ground-station
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180619/7a13a9a8/attachment.html>
