Jan Schiefer
jan at akalaitis.net
Tue Jun 19 16:37:18 PDT 2018
Hi Steve,
Can you please file an issue in the GitHub repo, so others are aware of the problem and can do something about it if they wish?
This is also helps us practice handling contributions from the community in an efficient manner.
Thanks,
Jan, ac7td
On Jun 19, 2018 12:39 PM, Steve Conklin via Ground-Station <ground-station at lists.openresearch.institute> wrote:
> I had a go at building it on Ubuntu 16.04 (Xenial). I needed the more recent fftw version but building and installing the tarball as directed in the 'dependencies' file failed to resolve the issue.
> The exact failure is an implicit declaration of fftwf_make_planner_thread_safe(), presumably because the right library version headers are not in place.
> I don't have more time to look at this at the moment but I'll get back to it eventually.
> On Mon, Jun 18, 2018 at 10:56 AM, Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute> wrote:
>> KA9Q SDR repository has been updated with the help of Jan Shiefer.
>> https://github.com/phase4ground/ka9q-sdr
>> There is a lot of great code in here. Leveraging IP Multicast and the method of providing metadata for IQ samples are two big concepts that we should talk a lot more about.
>> We've been asked to write a paper about it, so I've started working specifically on that with Phil to make it as easy as possible to get a clear description of the advantages and innovations.
