Paul Williamson
paul at mustbeart.com
Tue Jun 19 21:12:20 PDT 2018
It built successfully for me on Raspbian after I added one additional
dependency: libncurses5-dev
That is, it built without error messages. I haven't attempted to run it yet!
-Paul KB5MU
On Tue, Jun 19, 2018 at 4:58 PM, Michelle Thompson via Ground-Station <
> Same results here with building. Good idea on the issue filing.
> On Tue, Jun 19, 2018 at 4:37 PM, Jan Schiefer <jan at akalaitis.net> wrote:
>> Hi Steve,
>> Can you please file an issue in the GitHub repo, so others are aware of
>> the problem and can do something about it if they wish?
>> This is also helps us practice handling contributions from the community
>> in an efficient manner.
>> Thanks,
>> Jan, ac7td
>> On Jun 19, 2018 12:39 PM, Steve Conklin via Ground-Station
>> > I had a go at building it on Ubuntu 16.04 (Xenial). I needed the more
>> recent fftw version but building and installing the tarball as directed in
>> the 'dependencies' file failed to resolve the issue.
>> > The exact failure is an implicit declaration
>> of fftwf_make_planner_thread_safe(), presumably because the right
>> library version headers are not in place.
>> > I don't have more time to look at this at the moment but I'll get back
>> to it eventually.
>> > On Mon, Jun 18, 2018 at 10:56 AM, Michelle Thompson via Ground-Station
>> >> KA9Q SDR repository has been updated with the help of Jan Shiefer.
>> >> https://github.com/phase4ground/ka9q-sdr
>> >> There is a lot of great code in here. Leveraging IP Multicast and the
>> method of providing metadata for IQ samples are two big concepts that we
>> should talk a lot more about.
>> >> We've been asked to write a paper about it, so I've started working
>> specifically on that with Phil to make it as easy as possible to get a
>> clear description of the advantages and innovations.
>> >> -Michelle W5NYV
>> >> _______________________________________________
>> >> Ground-Station mailing list
>> >> Ground-Station at lists.openresearch.institute
>> >> http://lists.openresearch.institute/mailman/listinfo/ground-station
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180619/dc6b8d19/attachment.html>
