[Ground-station] Weekly report - 10GHz Balloon Launch - antenna options update
Mon Dec 3 17:45:16 PST 2018
Let's make some!
On Mon, Dec 3, 2018 at 5:43 PM KENT BRITAIN <wa5vjb at flash.net> wrote:
> 10 GHz version would of course be much smaller.
> On Mon, 12/3/18, Michelle Thompson via Ground-Station
> Subject: [Ground-station] Weekly report - 10GHz Balloon Launch - antenna
> options update
> To: "Michelle Thompson via Ground-Station"
> Date: Monday, December 3, 2018, 7:27 PM
> Testing 10GHz antenna structures for terrestrial,
> balloon, and satellite applications is part of what we
> do!
> Both existing and new 10GHz antenna designs are in
> progress for use on a high altitude balloon.
> The goal is to transmit DVB-S2/X live video from
> a high altitude balloon. This tests transmitter, antenna,
> processing, and sensing. Next steps would be two-way
> communications on 10GHz.
> High altitude balloon antennas have uncontrolled
> yaw. The current requirements are inexpensive enough to
> lose, hemispherical coverage, optimal gain at 70 degrees,
> some gain at 0 degrees (directly beneath the balloon).
> Circular polarization would be ideal. Otherwise,
> polarization tracking at the ground is required.
> Four different quadrifilar helix structures were
> simulated that gave a reasonable pattern. The problem so far
> is that these are easily realizable at GPS or 23cm
> frequencies, but the dimensions will be unreasonably small
> at 10.45GHz.
> Another new design is a patch array model. Most
> accessible papers at or near 10GHz for circular polarized
> patch arrays seem to be a record of capturing results of
> trial and error. This gives shapes that can be (in most
> cases) duplicated, but does not give a model that can be
> manipulated and edited to better match the
> requirements.
> Another aspect of the published work is the heavy
> influence of industrial and commercial requirements on
> antenna design. Very broadband designs that allow 2-3 or
> more bands are the goal. The pattern doesn't have to be
> great and the gain isn't that critical. When the device
> is held near, say, a body, then the pattern is messed up
> from the get go, so optimizing (and adding expense) is not
> generally pursued.
> So, that's where we come in. We don't
> have the same motivations or requirements as a commercial
> antenna deployment. We do need this antenna to be
> inexpensive enough to lose. Balloon payloads (and
> satellites, and even terrestrial gear) are lost in accidents
> and failures.
> Kent Britain's Vivaldi antenna is an existing
> inexpensive design scheduled to be integrated and tested
> with the payload.
> You might be saying "Wait, Vivaldis are only
> linear polarized" and yes you would be right. A single
> Vivaldi as the downlink antenna would give the right pattern
> but linear polarization, meaning polarization losses on the
> ground. Mitigations would be a challenge.
> However, Vivaldi antennas can be made to be
> circularly polarized in combination.
> To achieve this, two Vivaldi antennas are
> orthogonally placed. They are driven by a specially designed
> feeding network that creates an input signal with two-way
> signals that have equal magnitude and orthogonal phase. This
> can be done with PCB techniques.
> Next steps? Antenna simulation, building,
> testing, and flying!
> Comment and critique welcome and
> encouraged.
> Volunteers of any level accepted and
> supported.
> -----Inline Attachment Follows-----
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20181203/eccf4a51/attachment.html>
