[Ground-station] Weekly report - 10GHz Balloon Launch - antenna options update
Mon Dec 3 17:43:18 PST 2018
10 GHz version would of course be much smaller.
On Mon, 12/3/18, Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Subject: [Ground-station] Weekly report - 10GHz Balloon Launch - antenna options update
To: "Michelle Thompson via Ground-Station" <ground-station at lists.openresearch.institute>
Date: Monday, December 3, 2018, 7:27 PM
Testing 10GHz antenna structures for terrestrial,
balloon, and satellite applications is part of what we
do!
Both existing and new 10GHz antenna designs are in
progress for use on a high altitude balloon.
The goal is to transmit DVB-S2/X live video from
a high altitude balloon. This tests transmitter, antenna,
processing, and sensing. Next steps would be two-way
communications on 10GHz.
High altitude balloon antennas have uncontrolled
yaw. The current requirements are inexpensive enough to
lose, hemispherical coverage, optimal gain at 70 degrees,
some gain at 0 degrees (directly beneath the balloon).
Circular polarization would be ideal. Otherwise,
polarization tracking at the ground is required.
Four different quadrifilar helix structures were
simulated that gave a reasonable pattern. The problem so far
is that these are easily realizable at GPS or 23cm
frequencies, but the dimensions will be unreasonably small
at 10.45GHz.
Another new design is a patch array model. Most
accessible papers at or near 10GHz for circular polarized
patch arrays seem to be a record of capturing results of
trial and error. This gives shapes that can be (in most
cases) duplicated, but does not give a model that can be
manipulated and edited to better match the
requirements.
Another aspect of the published work is the heavy
influence of industrial and commercial requirements on
antenna design. Very broadband designs that allow 2-3 or
more bands are the goal. The pattern doesn't have to be
great and the gain isn't that critical. When the device
is held near, say, a body, then the pattern is messed up
from the get go, so optimizing (and adding expense) is not
generally pursued.
So, that's where we come in. We don't
have the same motivations or requirements as a commercial
antenna deployment. We do need this antenna to be
inexpensive enough to lose. Balloon payloads (and
satellites, and even terrestrial gear) are lost in accidents
and failures.
Kent Britain's Vivaldi antenna is an existing
inexpensive design scheduled to be integrated and tested
with the payload.
You might be saying "Wait, Vivaldis are only
linear polarized" and yes you would be right. A single
Vivaldi as the downlink antenna would give the right pattern
but linear polarization, meaning polarization losses on the
ground. Mitigations would be a challenge.
However, Vivaldi antennas can be made to be
circularly polarized in combination.
To achieve this, two Vivaldi antennas are
orthogonally placed. They are driven by a specially designed
feeding network that creates an input signal with two-way
signals that have equal magnitude and orthogonal phase. This
can be done with PCB techniques.
Next steps? Antenna simulation, building,
testing, and flying!
Comment and critique welcome and
encouraged.
Volunteers of any level accepted and
supported.
Ground-Station mailing list
-----Inline Attachment Follows-----
Name: Vivaldi with CP Lens.jpg
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20181204/103b199d/attachment.jpg>
Name: Vivaldi with CP Lens Front view.jpg
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20181204/103b199d/attachment-0001.jpg>
