Ron Economos
w6rz at comcast.net
Mon Apr 30 18:02:24 PDT 2018
Here are my results from testing the LMS8001a Companion Board as a 5.6
GHz to 755 MHz down converter. I'm using an indirect method to evaluate
phase noise by using a 64QAM CATV demodulator. The setup is Ettus B210
-> down converter -> 64QAM demodulator. All tests were done with an
external 5 volt power supply as recommended by Lime.
Here's the LMS8001a.
lms8001 phase noise
Here's the Kuhne 5.6 GHz down converter.
https://www.kuhne-electronic.de/funk/en/shop/industrial/prof-converter/prof-low-noise-conve/KU+LNC+5659+C+PRO++Down+Converter/?card=403
Kuhne phase noise
Very similar. I'd have to say the LMS8001 is doing a pretty good job.
Unfortunately, I can't tell how much phase noise is from the B210 and
how much is from the down converter.
There are a lot of spurs though. Here's with the 64QAM signal at 755 MHz.
spurs with signal
And without the 64QAM signal. No change.
without signal
Zoomed in. Looks like there's a spur every 20 MHz. The reference clock
is 40 MHz.
zoomed
On 04/28/2018 01:09 PM, Michelle Thompson via Ground-Station wrote:
> Hi Mike,
> Were you able to get the measurements you were after last weekend?
> Waiting on u.FL cables to arrive in the mail today.
> On Mon, Apr 9, 2018 at 3:44 AM, Mike Seguin via Ground-Station
> Correction to LO leakage on 5 GHz. -53 dBc but I measured -47 dBm
> not -53 dBm.
> Next tests are NF and play with the GPI for selecting different
> LO's and channel configs.
> I have a GPIO board for my Lime and it works and is supported in
> LimeSDR#. Also, Simon (SDRConsole) has indicated he will support
> GPIO as well.
> Here's what LimeSDR# supports.
> - J12 connector GPIO
> - Outputs: 0-3 BPF (4 bits), 4-PTT (MOX)
> - Inputs: 5-PTT microphone, 6-keyer DASH, 7-keyer DOT
> LimeSDR# is based on PowerSDR and is at beta 0.5 now.
> Mike
> On 4/8/2018 6:54 PM, Mike Seguin via Ground-Station wrote:
> Hi Ron,
> Did some basic transmit tests today.
> 4/8/2018
> 10 GHz transmit section. CHA
> IF set at 1.298 GHz max +9 dBm
> LO set to 9.070
> 10.368 -7 dBm
> LO @ -47 dBc (measured -54 dBm)
> 5 GHz transmit section. CHD
> IF set at 1.350 GHz max +9 dBm
> LO set to 4.5 GHz
> 5.850 +6 dBm
> LO @ -53 dBc (measured -53 dBm)
> === output in the 9-10 GHz range where the board is tuned ===
> 9.0 GHz +1 dBm
> 9.3 GHz -2 dBm
> 9.7 GHz -6 dBm
> 10 GHz -7 dBm
> Board is set up for:
> IF 1-3 GHz
> Up/Dwn conversions 5-6 GHz & 9-10 GHz
> Mike
> On 4/8/2018 2:46 PM, Ron Economos via Ground-Station wrote:
> I have one. I'll be doing some phase noise testing with
> 5.6 GHz down conversion soon.
> Ron W6RZ
> On 04/08/2018 03:57 AM, Mike Seguin via Ground-Station wrote:
> Anyone on the list working with the Lime LMS8001a
> Companion Board? Mine finally arrived and I'm starting
> to work with it. So far 10 GHz TX/RX is working
> (10.368 GHz). 10 MHz lock works well.
> Next is to try 5 GHz.
> At this point, no real measurements - just seeing
> signals going in/out and learning the setup.
> After initial sectional tests, I want to set it up as
> 5 GHz TX and 10 GHz receive.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180430/63eb17b6/attachment.html>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180430/63eb17b6/attachment.png>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180430/63eb17b6/attachment-0001.png>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180430/63eb17b6/attachment-0002.png>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180430/63eb17b6/attachment-0003.png>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180430/63eb17b6/attachment-0004.png>
