Sun Apr 8 17:39:04 PDT 2018
Got one here yesterday, looking forward to getting it stood up!
On Sun, Apr 8, 2018 at 3:57 AM, Mike Seguin via Ground-Station <
> Anyone on the list working with the Lime LMS8001a Companion Board? Mine
> finally arrived and I'm starting to work with it. So far 10 GHz TX/RX is
> working (10.368 GHz). 10 MHz lock works well.
> Next is to try 5 GHz.
> At this point, no real measurements - just seeing signals going in/out and
> learning the setup.
> After initial sectional tests, I want to set it up as 5 GHz TX and 10 GHz
> receive.
> 73,
> Mike, N1JEZ
> "A closed mouth gathers no feet"
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180408/ff4c2494/attachment.html>
