Sat Apr 28 13:09:13 PDT 2018
Hi Mike,
Were you able to get the measurements you were after last weekend?
Waiting on u.FL cables to arrive in the mail today.
On Mon, Apr 9, 2018 at 3:44 AM, Mike Seguin via Ground-Station <
> Correction to LO leakage on 5 GHz. -53 dBc but I measured -47 dBm not -53
> dBm.
> Next tests are NF and play with the GPI for selecting different LO's and
> channel configs.
> I have a GPIO board for my Lime and it works and is supported in LimeSDR#.
> Also, Simon (SDRConsole) has indicated he will support GPIO as well.
> Here's what LimeSDR# supports.
> - J12 connector GPIO
> - Outputs: 0-3 BPF (4 bits), 4-PTT (MOX)
> - Inputs: 5-PTT microphone, 6-keyer DASH, 7-keyer DOT
> LimeSDR# is based on PowerSDR and is at beta 0.5 now.
> Mike
> On 4/8/2018 6:54 PM, Mike Seguin via Ground-Station wrote:
>> Hi Ron,
>> Did some basic transmit tests today.
>> 4/8/2018
>> 10 GHz transmit section. CHA
>> IF set at 1.298 GHz max +9 dBm
>> LO set to 9.070
>> 10.368 -7 dBm
>> LO @ -47 dBc (measured -54 dBm)
>> 5 GHz transmit section. CHD
>> IF set at 1.350 GHz max +9 dBm
>> LO set to 4.5 GHz
>> 5.850 +6 dBm
>> LO @ -53 dBc (measured -53 dBm)
>> === output in the 9-10 GHz range where the board is tuned ===
>> 9.0 GHz +1 dBm
>> 9.3 GHz -2 dBm
>> 9.7 GHz -6 dBm
>> 10 GHz -7 dBm
>> Board is set up for:
>> IF 1-3 GHz
>> Up/Dwn conversions 5-6 GHz & 9-10 GHz
>> Mike
>> On 4/8/2018 2:46 PM, Ron Economos via Ground-Station wrote:
>>> I have one. I'll be doing some phase noise testing with 5.6 GHz down
>>> conversion soon.
>>> Ron W6RZ
>>> On 04/08/2018 03:57 AM, Mike Seguin via Ground-Station wrote:
>>>> Anyone on the list working with the Lime LMS8001a Companion Board? Mine
>>>> finally arrived and I'm starting to work with it. So far 10 GHz TX/RX is
>>>> working (10.368 GHz). 10 MHz lock works well.
>>>> Next is to try 5 GHz.
>>>> At this point, no real measurements - just seeing signals going in/out
>>>> and learning the setup.
>>>> After initial sectional tests, I want to set it up as 5 GHz TX and 10
>>>> GHz receive.
> 73,
> Mike, N1JEZ
> "A closed mouth gathers no feet"
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180428/5e3204ab/attachment.html>
