Ron Economos
w6rz at comcast.net
Fri Apr 20 12:37:26 PDT 2018
Unfortunately, the use of U.FL connectors make this product absolutely
useless (at least for me). At this point, I'm going to see if it blends.
On 04/16/2018 06:43 PM, Michelle Thompson via Ground-Station wrote:
> Taking your results and the board to San Diego Microwave Group meeting
> tonight.
> On Mon, Apr 9, 2018 at 3:44 AM, Mike Seguin via Ground-Station
> Correction to LO leakage on 5 GHz. -53 dBc but I measured -47 dBm
> not -53 dBm.
> Next tests are NF and play with the GPI for selecting different
> LO's and channel configs.
> I have a GPIO board for my Lime and it works and is supported in
> LimeSDR#. Also, Simon (SDRConsole) has indicated he will support
> GPIO as well.
> Here's what LimeSDR# supports.
> - J12 connector GPIO
> - Outputs: 0-3 BPF (4 bits), 4-PTT (MOX)
> - Inputs: 5-PTT microphone, 6-keyer DASH, 7-keyer DOT
> LimeSDR# is based on PowerSDR and is at beta 0.5 now.
> Mike
> On 4/8/2018 6:54 PM, Mike Seguin via Ground-Station wrote:
> Hi Ron,
> Did some basic transmit tests today.
> 4/8/2018
> 10 GHz transmit section. CHA
> IF set at 1.298 GHz max +9 dBm
> LO set to 9.070
> 10.368 -7 dBm
> LO @ -47 dBc (measured -54 dBm)
> 5 GHz transmit section. CHD
> IF set at 1.350 GHz max +9 dBm
> LO set to 4.5 GHz
> 5.850 +6 dBm
> LO @ -53 dBc (measured -53 dBm)
> === output in the 9-10 GHz range where the board is tuned ===
> 9.0 GHz +1 dBm
> 9.3 GHz -2 dBm
> 9.7 GHz -6 dBm
> 10 GHz -7 dBm
> Board is set up for:
> IF 1-3 GHz
> Up/Dwn conversions 5-6 GHz & 9-10 GHz
> Mike
> On 4/8/2018 2:46 PM, Ron Economos via Ground-Station wrote:
> I have one. I'll be doing some phase noise testing with
> 5.6 GHz down conversion soon.
> Ron W6RZ
> On 04/08/2018 03:57 AM, Mike Seguin via Ground-Station wrote:
> Anyone on the list working with the Lime LMS8001a
> Companion Board? Mine finally arrived and I'm starting
> to work with it. So far 10 GHz TX/RX is working
> (10.368 GHz). 10 MHz lock works well.
> Next is to try 5 GHz.
> At this point, no real measurements - just seeing
> signals going in/out and learning the setup.
> After initial sectional tests, I want to set it up as
> 5 GHz TX and 10 GHz receive.
> <http://lists.openresearch.institute/mailman/listinfo/ground-station>
> 73,
> Mike, N1JEZ
> "A closed mouth gathers no feet"
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180420/4f687f38/attachment.html>
