Mon Apr 16 18:43:32 PDT 2018
Taking your results and the board to San Diego Microwave Group meeting
tonight.
On Mon, Apr 9, 2018 at 3:44 AM, Mike Seguin via Ground-Station <
> Correction to LO leakage on 5 GHz. -53 dBc but I measured -47 dBm not -53
> dBm.
> Next tests are NF and play with the GPI for selecting different LO's and
> channel configs.
> I have a GPIO board for my Lime and it works and is supported in LimeSDR#.
> Also, Simon (SDRConsole) has indicated he will support GPIO as well.
> Here's what LimeSDR# supports.
> - J12 connector GPIO
> - Outputs: 0-3 BPF (4 bits), 4-PTT (MOX)
> - Inputs: 5-PTT microphone, 6-keyer DASH, 7-keyer DOT
> LimeSDR# is based on PowerSDR and is at beta 0.5 now.
> Mike
> On 4/8/2018 6:54 PM, Mike Seguin via Ground-Station wrote:
>> Hi Ron,
>> Did some basic transmit tests today.
>> 4/8/2018
>> 10 GHz transmit section. CHA
>> IF set at 1.298 GHz max +9 dBm
>> LO set to 9.070
>> 10.368 -7 dBm
>> LO @ -47 dBc (measured -54 dBm)
>> 5 GHz transmit section. CHD
>> IF set at 1.350 GHz max +9 dBm
>> LO set to 4.5 GHz
>> 5.850 +6 dBm
>> LO @ -53 dBc (measured -53 dBm)
>> === output in the 9-10 GHz range where the board is tuned ===
>> 9.0 GHz +1 dBm
>> 9.3 GHz -2 dBm
>> 9.7 GHz -6 dBm
>> 10 GHz -7 dBm
>> Board is set up for:
>> IF 1-3 GHz
>> Up/Dwn conversions 5-6 GHz & 9-10 GHz
>> Mike
>> On 4/8/2018 2:46 PM, Ron Economos via Ground-Station wrote:
>>> I have one. I'll be doing some phase noise testing with 5.6 GHz down
>>> conversion soon.
>>> Ron W6RZ
>>> On 04/08/2018 03:57 AM, Mike Seguin via Ground-Station wrote:
>>>> Anyone on the list working with the Lime LMS8001a Companion Board? Mine
>>>> finally arrived and I'm starting to work with it. So far 10 GHz TX/RX is
>>>> working (10.368 GHz). 10 MHz lock works well.
>>>> Next is to try 5 GHz.
>>>> At this point, no real measurements - just seeing signals going in/out
>>>> and learning the setup.
>>>> After initial sectional tests, I want to set it up as 5 GHz TX and 10
>>>> GHz receive.
> 73,
> Mike, N1JEZ
> "A closed mouth gathers no feet"
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180416/57230376/attachment.html>
