Tue Apr 24 07:07:58 PDT 2018
Yes on the LICENSE file. We are GPL 3.0, and several people have pointed
out that the source repo doesn't have one.
On Tue, Apr 24, 2018 at 6:53 AM, Michelle Thompson <
> Thank you Jan.
> I would like to keep the project repository current with this code.
> Phil is a novice at github, and could use the help in learning how to use
> it.
> I’ll add you to the team I set up for him as the maintainer on our Github.
> Maybe after he sees the process it will be easier for him to collaborate.
> *mdt
> On Tue, Apr 24, 2018 at 02:16 Jan Schiefer via Ground-Station
>> > In the file named "dependencies". Look in ka9q/ka9q-radio, not
>> > phase4ground/ka9q-sdr. I created and began to revise the first before I
>> > realized I'd created a private repository. If somebody can figure out
>> > how to just rename the whole thing, I gladly will.
>> > You know, "mv ka9q/ka9q-radio phase4ground/ka9q-sdr"
>> > I also put stuff in phase4ground/ka9q-sdr but I have NOT been updating
>> > it. I should probably delete it so it won't confuse people.
>> I merged the changes, but I don't have write permissions for
>> phase4ground/ka9q-sdr. Michelle, if you want to give me write
>> permissions, I'll push it. If you'd rather I sent you a pull request,
>> that's perfectly fine, too.
>> The intended end result is that the contents of ka9q/ka9q-radio and
>> phase4ground/ka9q-sdr will be the same, with the one exception of the
>> LICENSE file, which I assume we would want in there.
>> Cheers,
>> Jan, ac7td
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180424/8ddae621/attachment.html>
