Tue Apr 24 06:53:39 PDT 2018
Thank you Jan.
I would like to keep the project repository current with this code.
Phil is a novice at github, and could use the help in learning how to use
it.
I’ll add you to the team I set up for him as the maintainer on our Github.
Maybe after he sees the process it will be easier for him to collaborate.
*mdt
On Tue, Apr 24, 2018 at 02:16 Jan Schiefer via Ground-Station
> > In the file named "dependencies". Look in ka9q/ka9q-radio, not
> > phase4ground/ka9q-sdr. I created and began to revise the first before I
> > realized I'd created a private repository. If somebody can figure out
> > how to just rename the whole thing, I gladly will.
> > You know, "mv ka9q/ka9q-radio phase4ground/ka9q-sdr"
> > I also put stuff in phase4ground/ka9q-sdr but I have NOT been updating
> > it. I should probably delete it so it won't confuse people.
> I merged the changes, but I don't have write permissions for
> phase4ground/ka9q-sdr. Michelle, if you want to give me write
> permissions, I'll push it. If you'd rather I sent you a pull request,
> that's perfectly fine, too.
> The intended end result is that the contents of ka9q/ka9q-radio and
> phase4ground/ka9q-sdr will be the same, with the one exception of the
> LICENSE file, which I assume we would want in there.
> Cheers,
> Jan, ac7td
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180424/68bc746d/attachment.html>
