Bruce Perens
bruce at perens.com
Mon Apr 23 17:13:23 PDT 2018
The dependency should specify GCC 4.9 and above. You should also compile
with the -std=c++11 flag.
On Mon, Apr 23, 2018 at 5:09 PM, Douglas Quagliana via Ground-Station <
> And, of course, as soon as I said that it finished. So, with fftw3
> installed,
> running 'make' in ka9q-radio compiles much of it but it errors out saying
> monitor.c:5:23: fatal error: stdatomic.h: No such file or directory
> #include <stdatomic.h>
> compilation terminated.
> make: *** [monitor.o] Error 1
> ~/projects/ka9q-sdr/ka9q-radio$ locate -ir stdatomic.h
> ~/projects/ka9q-sdr/ka9q-radio$ gcc --version
> gcc (Ubuntu 4.8.4-2ubuntu1~14.04.4) 4.8.4
> My guess is that the gcc in this version of Ubuntu is either too old
> or missing some package that contains stdatomic.h ?
> Douglas
> "Maybe I should just try this on Ubuntu 1604LTS..."
> On Mon, Apr 23, 2018 at 6:57 PM, Douglas Quagliana <dquagliana at gmail.com>
> wrote:
>> Phil writes:
>> > I'm continuing to revise the comments and documentation in
>> >ka9q/ka9q-radio. I just revised the file "dependencies" that describes
>> >what you need to install and build it, including the "apt install"
>> >commands for Debian Linux, Rasbian or Ubuntu.
>> Which file are the dependencies listed in?
>> Also, on Ubuntu 14.04LTS I needed to install libusb-1.0-0-dev and
>> then it only gave an error on fftw3. The 'make' for fftw3 is taking
>> longer than I thought. :-)
>> Douglas
>> On Sun, Apr 22, 2018 at 9:13 PM, Phil Karn <karn at ka9q.net> wrote:
>>> On 4/22/18 06:10, Douglas Quagliana wrote:
>>> > The original text says that this ran from a command line on Linux. I
>>> > did a git clone, ran make but got numerous errors compiling
>>> > (bsd/strings.h) and errors linking (-lbsd in particular)
>>> > I'd love to try it and make a GUI (if I can).
>>> > Which Linux distribution did you use?
>>> > Which version of gcc?
>>> I eventually managed to push my stuff up to phase4ground/ka9q-sdr, but
>>> this was after I'd created ka9q/ka9q-radio and revised it a few times.
>>> So ignore phase4ground/ka9q-sdr for now and use ka9q/ka9q-radio until I
>>> can figure out how to migrate or rename it.
>>> My primary target is Raspbian on the Raspberry Pi, which is essentially
>>> identical to Debian Linux which I run on my x86 systems. (Ubuntu is also
>>> essentially Debian inside.) So you need to run a few "apt install"
>>> commands and then do a make.
>>> Good luck! Let me know how it goes.
>>> --Phil
Bruce Perens K6BP - Standards committee chair, license review committee
member, Open Source Initiative
President, Open Research Institute
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180423/942df237/attachment.html>
