Douglas Quagliana
dquagliana at gmail.com
Mon Apr 23 17:09:28 PDT 2018
And, of course, as soon as I said that it finished. So, with fftw3
installed,
running 'make' in ka9q-radio compiles much of it but it errors out saying
monitor.c:5:23: fatal error: stdatomic.h: No such file or directory
#include <stdatomic.h>
compilation terminated.
make: *** [monitor.o] Error 1
~/projects/ka9q-sdr/ka9q-radio$ locate -ir stdatomic.h
~/projects/ka9q-sdr/ka9q-radio$ gcc --version
gcc (Ubuntu 4.8.4-2ubuntu1~14.04.4) 4.8.4
My guess is that the gcc in this version of Ubuntu is either too old
or missing some package that contains stdatomic.h ?
Douglas
"Maybe I should just try this on Ubuntu 1604LTS..."
On Mon, Apr 23, 2018 at 6:57 PM, Douglas Quagliana <dquagliana at gmail.com>
wrote:
> Phil writes:
> > I'm continuing to revise the comments and documentation in
> >ka9q/ka9q-radio. I just revised the file "dependencies" that describes
> >what you need to install and build it, including the "apt install"
> >commands for Debian Linux, Rasbian or Ubuntu.
> Which file are the dependencies listed in?
> Also, on Ubuntu 14.04LTS I needed to install libusb-1.0-0-dev and
> then it only gave an error on fftw3. The 'make' for fftw3 is taking
> longer than I thought. :-)
> Douglas
> On Sun, Apr 22, 2018 at 9:13 PM, Phil Karn <karn at ka9q.net> wrote:
>> On 4/22/18 06:10, Douglas Quagliana wrote:
>> > The original text says that this ran from a command line on Linux. I
>> > did a git clone, ran make but got numerous errors compiling
>> > (bsd/strings.h) and errors linking (-lbsd in particular)
>> > I'd love to try it and make a GUI (if I can).
>> > Which Linux distribution did you use?
>> > Which version of gcc?
>> I eventually managed to push my stuff up to phase4ground/ka9q-sdr, but
>> this was after I'd created ka9q/ka9q-radio and revised it a few times.
>> So ignore phase4ground/ka9q-sdr for now and use ka9q/ka9q-radio until I
>> can figure out how to migrate or rename it.
>> My primary target is Raspbian on the Raspberry Pi, which is essentially
>> identical to Debian Linux which I run on my x86 systems. (Ubuntu is also
>> essentially Debian inside.) So you need to run a few "apt install"
>> commands and then do a make.
>> Good luck! Let me know how it goes.
>> --Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180423/a679728c/attachment.html>
