Douglas Quagliana
dquagliana at gmail.com
Mon Apr 23 16:57:33 PDT 2018
Phil writes:
> I'm continuing to revise the comments and documentation in
>ka9q/ka9q-radio. I just revised the file "dependencies" that describes
>what you need to install and build it, including the "apt install"
>commands for Debian Linux, Rasbian or Ubuntu.
Which file are the dependencies listed in?
Also, on Ubuntu 14.04LTS I needed to install libusb-1.0-0-dev and
then it only gave an error on fftw3. The 'make' for fftw3 is taking
longer than I thought. :-)
Douglas
On Sun, Apr 22, 2018 at 9:13 PM, Phil Karn <karn at ka9q.net> wrote:
> On 4/22/18 06:10, Douglas Quagliana wrote:
> > The original text says that this ran from a command line on Linux. I
> > did a git clone, ran make but got numerous errors compiling
> > (bsd/strings.h) and errors linking (-lbsd in particular)
> > I'd love to try it and make a GUI (if I can).
> > Which Linux distribution did you use?
> > Which version of gcc?
> I eventually managed to push my stuff up to phase4ground/ka9q-sdr, but
> this was after I'd created ka9q/ka9q-radio and revised it a few times.
> So ignore phase4ground/ka9q-sdr for now and use ka9q/ka9q-radio until I
> can figure out how to migrate or rename it.
> My primary target is Raspbian on the Raspberry Pi, which is essentially
> identical to Debian Linux which I run on my x86 systems. (Ubuntu is also
> essentially Debian inside.) So you need to run a few "apt install"
> commands and then do a make.
> Good luck! Let me know how it goes.
> --Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180423/2c687691/attachment.html>
