Edson W. R. Pereira
ewpereira at gmail.com
Sun Apr 22 14:52:40 PDT 2018
Hi Ron,
You are right. That was a typo. Thanks for the correction.
73, Edson PY2SDR
On Sun, Apr 22, 2018 at 4:18 PM, Ron Economos via Ground-Station <
> Look like it's portaudio19-dev, not libportaudio19-dev.
> Ron W6RZ
> On 04/22/2018 11:48 AM, Edson W. R. Pereira via Ground-Station wrote:
> It is very nice to see a modular implementation for a SDR application.
> Thank you very much for all your work, Phil. This is a wonderful gift for
> those of us that like to tinker with SDR and unix.
> Some compilation notes for Ubuntu 16.04:
> sudo apt-get install libbsd-dev libattr1-dev libopus-dev
> libportaudio19-dev libncurses-dev
> I had to compile a recent version for libfftw3 (version 3.3.7) since the
> one in the Ubuntu repository (version 3.3.4) did not have
> fftwf_make_planner_thread_safe() implemented. To compile lib fftw3,
> wget http://www.fftw.org/fftw-3.3.7.tar.gz
> tar -zxvf fftw-3.3.7.tar.gz
> cd fftw3-3.3.7
> ./configure --enable-float --enable-threads
> make
> make install
> Then download and unzip the ka9q-radio sources, edit the Makefile and add
> the path to fftw3. This is the diff.
> 3c3
> < INCLUDES=
> > INCLUDES=-I/usr/local/include
> 27c27
> < $(CC) -g -o $@ $^ -lfftw3f_threads -lfftw3f -lbsd -lm -lpthread
> > $(CC) -g -o $@ $^ -L/usr/local/lib -lfftw3f_threads -lfftw3f -lbsd
> -lm -lpthread
> 57c57
> < $(CC) -g -o $@ $^ -lfftw3f_threads -lfftw3f -lncurses -lbsd -lm
> -lpthread
> -lncurses -lbsd -lm -lpthread
> 73, Edson PY2SDR
> On Sun, Apr 22, 2018 at 10:10 AM, Douglas Quagliana via Ground-Station <
>> The original text says that this ran from a command line on Linux. I did
>> a git clone, ran make but got numerous errors compiling (bsd/strings.h)
>> and errors linking (-lbsd in particular)
>> I'd love to try it and make a GUI (if I can).
>> Which Linux distribution did you use?
>> Which version of gcc?
>> Douglas
>> On Saturday, April 21, 2018, Michelle Thompson via Ground-Station
>>> This software is in the repository here https://github.com/phase4groun
>>> d/ka9q-sdr
>>> -Michelle W5NYV
>>> On Sat, Apr 21, 2018 at 9:48 PM, Phil Karn via Ground-Station <
>>>> On 4/21/18 14:36, Douglas Quagliana via Ground-Station wrote:
>>>> > Hi Michelle,
>>>> > Here's my first pass. Suggested changes:
>>>> > change "aquire" to "acquire"
>>>> > change "unecessarily" to "unnecessarily"
>>>> > change "Curently" to "Currently"
>>>> > change ""imabalance" to "imbalance"
>>>> > change "ony" to "only"
>>>> > change "demdulator" to "demodulator"
>>>> > change ""operating moded" to "operating mode" ?
>>>> > change "recordingq" to "recording"
>>>> Yeah, I didn't run a spell checker before I shipped it off.
>>>> > For the sentence containing "...this noise is only
>>>> > noticeable in without antenna noise covering it up"
>>>> > remove the "in" or rewrite.
>>>> > I would suggest a slightly different frequency for the example
>>>> > "147m435" (147.435 MHz) as "435" is frequently used in the
>>>> > context of 435 MHz (at least for satellite work) and this might
>>>> > cause some confusion.
>>>> I picked 147.435 as an in-joke for hams in southern California. It's the
>>>> output of the infamous "animal house" repeater in Los Angeles. But point
>>>> taken.
>>>> > In written text, the FUNcube dongle is usually written as "FUNcube"
>>>> > with the first three letters capitalized (Source:
>>>> > http://www.funcubedongle.com/)
>>>> I was wondering about this. "Funcube dongle pro+" is a bit of a mouthful
>>>> but "Funcube" by itself refers to the satellite.
>>>> > Is there a link to download the software?
>>>> There will be...
>>>> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180422/2f3640a2/attachment.html>
