Ron Economos
w6rz at comcast.net
Sun Apr 22 12:18:30 PDT 2018
Look like it's portaudio19-dev, not libportaudio19-dev.
On 04/22/2018 11:48 AM, Edson W. R. Pereira via Ground-Station wrote:
> It is very nice to see a modular implementation for a SDR application.
> Thank you very much for all your work, Phil. This is a wonderful gift
> for those of us that like to tinker with SDR and unix.
> Some compilation notes for Ubuntu 16.04:
> sudo apt-get install libbsd-dev libattr1-dev libopus-dev
> libportaudio19-dev libncurses-dev
> I had to compile a recent version for libfftw3 (version 3.3.7) since
> the one in the Ubuntu repository (version 3.3.4) did not have
> fftwf_make_planner_thread_safe() implemented. To compile lib fftw3,
> wget http://www.fftw.org/fftw-3.3.7.tar.gz
> tar -zxvf fftw-3.3.7.tar.gz
> cd fftw3-3.3.7
> ./configure --enable-float --enable-threads
> make
> make install
> Then download and unzip the ka9q-radio sources, edit the Makefile and
> add the path to fftw3. This is the diff.
> 3c3
> < INCLUDES=
> > INCLUDES=-I/usr/local/include
> 27c27
> < $(CC) -g -o $@ $^ -lfftw3f_threads -lfftw3f -lbsd -lm -lpthread
> > $(CC) -g -o $@ $^ -L/usr/local/lib -lfftw3f_threads -lfftw3f
> -lbsd -lm -lpthread
> 57c57
> < $(CC) -g -o $@ $^ -lfftw3f_threads -lfftw3f -lncurses -lbsd -lm
> -lpthread
> -lncurses -lbsd -lm -lpthread
> 73, Edson PY2SDR
> On Sun, Apr 22, 2018 at 10:10 AM, Douglas Quagliana via Ground-Station
> The original text says that this ran from a command line on
> Linux. I did a git clone, ran make but got numerous errors
> compiling (bsd/strings.h) and errors linking (-lbsd in particular)
> I'd love to try it and make a GUI (if I can).
> Which Linux distribution did you use?
> Which version of gcc?
> Douglas
> On Saturday, April 21, 2018, Michelle Thompson via Ground-Station
> This software is in the repository here
> https://github.com/phase4ground/ka9q-sdr
> <https://github.com/phase4ground/ka9q-sdr>
> On Sat, Apr 21, 2018 at 9:48 PM, Phil Karn via Ground-Station
> On 4/21/18 14:36, Douglas Quagliana via Ground-Station wrote:
> > Hi Michelle,
> > Here's my first pass. Suggested changes:
> > change "aquire" to "acquire"
> > change "unecessarily" to "unnecessarily"
> > change "Curently" to "Currently"
> > change ""imabalance" to "imbalance"
> > change "ony" to "only"
> > change "demdulator" to "demodulator"
> > change ""operating moded" to "operating mode" ?
> > change "recordingq" to "recording"
> Yeah, I didn't run a spell checker before I shipped it off.
> > For the sentence containing "...this noise is only
> > noticeable in without antenna noise covering it up"
> > remove the "in" or rewrite.
> > I would suggest a slightly different frequency for the
> example
> > "147m435" (147.435 MHz) as "435" is frequently used in the
> > context of 435 MHz (at least for satellite work) and
> this might
> > cause some confusion.
> I picked 147.435 as an in-joke for hams in southern
> California. It's the
> output of the infamous "animal house" repeater in Los
> Angeles. But point
> taken.
> > In written text, the FUNcube dongle is usually written
> as "FUNcube"
> > with the first three letters capitalized (Source:
> > http://www.funcubedongle.com/)
> I was wondering about this. "Funcube dongle pro+" is a bit
> of a mouthful
> but "Funcube" by itself refers to the satellite.
> > Is there a link to download the software?
> There will be...
> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180422/7a79979b/attachment.html>
