Edson W. R. Pereira
ewpereira at gmail.com
Sun Apr 22 11:48:53 PDT 2018
It is very nice to see a modular implementation for a SDR application.
Thank you very much for all your work, Phil. This is a wonderful gift for
those of us that like to tinker with SDR and unix.
Some compilation notes for Ubuntu 16.04:
sudo apt-get install libbsd-dev libattr1-dev libopus-dev libportaudio19-dev
libncurses-dev
I had to compile a recent version for libfftw3 (version 3.3.7) since the
one in the Ubuntu repository (version 3.3.4) did not have
fftwf_make_planner_thread_safe() implemented. To compile lib fftw3,
wget http://www.fftw.org/fftw-3.3.7.tar.gz
tar -zxvf fftw-3.3.7.tar.gz
cd fftw3-3.3.7
./configure --enable-float --enable-threads
make
make install
Then download and unzip the ka9q-radio sources, edit the Makefile and add
the path to fftw3. This is the diff.
3c3
< INCLUDES=
> INCLUDES=-I/usr/local/include
27c27
< $(CC) -g -o $@ $^ -lfftw3f_threads -lfftw3f -lbsd -lm -lpthread
> $(CC) -g -o $@ $^ -L/usr/local/lib -lfftw3f_threads -lfftw3f -lbsd
-lm -lpthread
57c57
< $(CC) -g -o $@ $^ -lfftw3f_threads -lfftw3f -lncurses -lbsd -lm
-lpthread
-lncurses -lbsd -lm -lpthread
73, Edson PY2SDR
On Sun, Apr 22, 2018 at 10:10 AM, Douglas Quagliana via Ground-Station <
> The original text says that this ran from a command line on Linux. I did
> a git clone, ran make but got numerous errors compiling (bsd/strings.h)
> and errors linking (-lbsd in particular)
> I'd love to try it and make a GUI (if I can).
> Which Linux distribution did you use?
> Which version of gcc?
> Douglas
> On Saturday, April 21, 2018, Michelle Thompson via Ground-Station
>> This software is in the repository here https://github.com/phase4groun
>> d/ka9q-sdr
>> On Sat, Apr 21, 2018 at 9:48 PM, Phil Karn via Ground-Station <
>>> On 4/21/18 14:36, Douglas Quagliana via Ground-Station wrote:
>>> > Hi Michelle,
>>> > Here's my first pass. Suggested changes:
>>> > change "aquire" to "acquire"
>>> > change "unecessarily" to "unnecessarily"
>>> > change "Curently" to "Currently"
>>> > change ""imabalance" to "imbalance"
>>> > change "ony" to "only"
>>> > change "demdulator" to "demodulator"
>>> > change ""operating moded" to "operating mode" ?
>>> > change "recordingq" to "recording"
>>> Yeah, I didn't run a spell checker before I shipped it off.
>>> > For the sentence containing "...this noise is only
>>> > noticeable in without antenna noise covering it up"
>>> > remove the "in" or rewrite.
>>> > I would suggest a slightly different frequency for the example
>>> > "147m435" (147.435 MHz) as "435" is frequently used in the
>>> > context of 435 MHz (at least for satellite work) and this might
>>> > cause some confusion.
>>> I picked 147.435 as an in-joke for hams in southern California. It's the
>>> output of the infamous "animal house" repeater in Los Angeles. But point
>>> taken.
>>> > In written text, the FUNcube dongle is usually written as "FUNcube"
>>> > with the first three letters capitalized (Source:
>>> > http://www.funcubedongle.com/)
>>> I was wondering about this. "Funcube dongle pro+" is a bit of a mouthful
>>> but "Funcube" by itself refers to the satellite.
>>> > Is there a link to download the software?
>>> There will be...
>>> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180422/a404ab40/attachment.html>
