[Ribbit-Developers] Generate ribbit messages from command line compatible with rattlegram
W4CKX
W4CKX at pekt.org
Thu May 16 00:37:18 PDT 2024
Hello Josh.
Thank you for reaching out.
The short answer is: Rattlegram and Ribbit are not compatible.
Rattlegram was put together very quickly by Ahmet reusing a lot of his
earlier CODFMTV work.
After Rattlegram demonstrated that it works, Ahmet went back to the design
board to build and optimize Ribbit from scratch.
Therefore Ribbit encoding improves on every measure compared to Rattlegram.
We are currently developing the Ribbit app to be a single codebase running
on all OS: Android, iOS, tablets, Windows, Linux and MacOS.
Let's keep in touch.
Pierre W4CKX
On Thu, May 16, 2024, 2:50 AM Josh Datko via Ribbit-Developers
<ribbit-developers at lists.openresearch.institute> wrote:
> I'm using the latest ribbit modem software from github. I'd like to
> generate messages on the command line, save the .wavs, and have them be
> compatible with rattlegram. Is this possible?
> For example, the ribbit encoder.cc modes only allow <14 or something. In
> any case, Rattlegram says "Mode 7 unsupported" or so when I produce a wave
> from the modem encoder.
> The point of this exercise is I would like to make an audio file with the
> ODFM encoded data. In this case, I don't really care about the ham radio
> application per se, it's just that rattlegram is quite nice and available.
> So it's easy just to have lots of people download the app and then decode
> the messages.
> Alternatively, I could enter all the messages in rattlegram, save the
> audio, which I have to collect somewhat awkwardly. This is possible, but
> undesirable.
> Josh
URL: <http://lists.openresearch.institute/pipermail/ribbit-developers-openresearch.institute/attachments/20240516/3662a56c/attachment.htm>
