[Ground-station] Presentation of Material to ESA
Mon Nov 27 08:15:41 PST 2023
Thank you to everyone involved with this effort. We simply could not
achieve ambitious things like this without broad, competent, and generous
participation.
We have provided technical support packages to AMSAT-UK, AMSAT-CA, and
AMSAT-DL.
We will also send a copy of the technical support package and our
Haifuraiya proposal directly to the ESA.
The meetings and conversations over the past week have been very good. The
organizations listed above have treated us with dignity, respect, and
inclusion. I have represented the work of all of our volunteers to the best
of my ability.
We'll talk about this at tomorrow's 1000 US Pacific meetup, along with
uplink development work. After the recorded session, there will be office
hours. This is where we take on all questions and comments off the record.
All are welcome.
On Tue, Nov 21, 2023 at 5:58 PM Michelle Thompson <
> Greetings all,
> Hat tip to Kent Britain for the following, which was in a recent issue of
> Scatterpoint, the UK Microwave journal.
> I'll forward everything relevant that we have been working on. It's quite
> a lot and should be helpful. Anyone that wants to help with this proposal
> and communication effort is of course welcome.
> Please read the announcement below and share your thoughts.
> "Satellite Proposal for discussion
> At the recent RSGB Convention / AMSAT-UK Colloquium at Milton Keynes,
> Frank Zeppenfeldt, PD0AP, from the European Space Agency Satellite
> Communications Group, made a presentation on the subject of a future ESA
> backed amateur satellite mission to GEO. Frank has obtained funding of
> 250,000 Euro to investigate the possibility of an Amateur satellite or
> payload to be placed in GEO orbit. The presentation emphasises innovation
> and microwave
> communications.
> Frank's full presentation is available on YouTube
> https://www.youtube.com/watch?v=_FTvlEyDa1Y&t=37s&pp=ygUYYW1zYXQgVUsgY29sbG9xdWl1bSAyMDIz
> As a member of the UK microwave / Satellite community, we would like to
> invite you to contribute to the design concept of this mission.
> We would welcome any thoughts you may have via e-mail etc. and we will add
> those to the overall discussion.
> In a follow up Teams meeting on Wed 1st Nov between Frank and AMSAT-UK, it
> became clear that an ideal solution from an ESA perspective should provide
> a service to amateurs in Canada as well as Europe. - Canada is an ESA
> cooperating state. Note that any GEO covering part or all of Canada will
> also cover a significant proportion of The USA.
> AMSAT-UK is working to identify a suitable range of GEO slots which meet
> this requirement.
> What is needed, is a proposal for 2 or 3 ideas for what this GEO mission
> (most likely a hosted payload) should include.
> See notes / Franks presentation.
> AMSAT-UK aims to respond with some proposals by Dec 4th. These do not need
> great detail, but should justify bands used and other ideas.
> For Example.
> What bands should be included. - This project is not aimed as a QO-100
> replacement.
> Is 24G and up practical? Can a ground station generate enough power
> economically with today’s available technology
> for an uplink on 24/47/76G
> Given a resource in space, is there an 'easy' entry level on say 24G - RX
> or TX so we can attract new microwave operators.
> Should the transponder/s be old style bent pipe configurations or contain
> on board processing to decode RX signals then encode the downlink?
> What digital protocols are appropriate for the above?
> Is 5.6G viable as an uplink given the WiFi presence?
> Any observations on 6cm interference would be valuable.
> Note: The antennas on the satellite will likely have a min gain of 20dB as
> this covers the visible portion of the Earth from geostationary orbit.
> In recent discussions with BATC etc we have concluded that a 10G downlink
> should be the baseline to take advantage of the large existing userbase and
> that a minimum power output onboard needs to be 10W into a 20dB antenna.
> If the proposals are considered substantial enough for further discussion,
> we have suggested a meeting at the ESA technical centre in The Netherlands
> around end Feb / March next year. This 2 day (?) event would be funded by
> ESA probably via A-UK. If this meeting happens, then representatives from
> A-UK BATC and UK microwave group could attend along with other groups from
> The EU and USA so we can take the project forward.
> Frank anticipates doing some initial prototyping and then present the
> findings to a meeting of GEO platform operators next year. Hopefully this
> will find a commercial partner with a platform going to an appropriate GEO
> slot.
> If any of this is of interest, please let us know your thoughts.
> This is a rare opportunity. I hope you can give it your support.
> David G0MRF / Noel G8GTZ"
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20231127/5e8da48d/attachment.htm>
