[Ground-station] #sprite_sat channel in Slack
Mon Mar 14 11:07:20 PDT 2022
We've renamed the #pcb_review channel to #sprite_sat to better capture the
work going on there with the AmbaSat 70cm project.
Want to help? You are welcome. If you're already on Slack you will see the
channel in the lefthand column.
If you're not, then get in touch and we'll get you onboarded.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20220314/e010f588/attachment.html>
