[Ground-station] Link budget
Thomas Savarino
thomas.savarino at mac.com
Wed Jan 20 12:39:43 PST 2021
I’d like to hear more about your Golang work and why you use that.
S
Sent from my iPhone
> On Jan 20, 2021, at 12:32 PM, Robert McGwier via Ground-Station <ground-station at lists.openresearch.institute> wrote:
> I want to strongly support python for the work. I do simulations in Matlab and some architecture design work and then I use python and I'm moving into Golang for compiled code.
> Bob
> Dr. Robert W McGwier, Ph.D.
> Adjunct Faculty, Virginia Tech
> ARDC Member of Board
> ARS: N4HY
> ARRL, AMSAT, AAVSO, TAPR, SkyHub
>> On Tue, Jan 19, 2021, 4:07 PM Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute> wrote:
>> Thank you Thomas and Alan for the valuable input.
>> I have a soft spot in my heart for Octave and MATLAB, and am used to having them be a significant part of technical work like this. If Python can do the job, and it's the preferred expression for the work, then by all means let's proceed.
>>> On Tue, Jan 19, 2021 at 2:03 PM Alan Rich <arich127 at gmail.com> wrote:
>>> Hi All ,
>>> My apologies for being really late / absent to respond to lots of the emails on this subject.
>>> I think I was the one that unfortunately dragged Octave into the discussion. The main reason was that I am not an experienced python person (yet) but I have contributed in the past to some Matlab utilities for RF work that were converted to executables in the end. Matlab isn't open source, but Octave is, and it was one of the original open engineering tools. It's been around for 20 plus years and has good community support. I was thinking that a link budget and propagation "Toolbox" for Octave might be a nice thing to have for the community.
>>> Given that python, numpy, scipy.. have really become the open source baseline, I'm sure that this is absolutely the right way to go for a mission application/planning tool. I apologize for the distraction.
>>> I'll experiment a bit over in Matlab/Octave in the background to see if a set of .m files or functions can be built up to support future work.
>>> Link budgets , Bus power budgets (and antenna pointing requirements) are so important. Everything else ( throughput and BER/SER/PER) falls out of them.
>>> Cheers!
>>> Alan
>>> Virus-free. www.avg.com
>>>> On Tue, Jan 19, 2021 at 3:56 PM Thomas Savarino <thomas.savarino at mac.com> wrote:
>>>> I understand that you don’t want any help with this, but I can’t resist mentioning that you’d probably be better off doing everything in python and avoiding the dependence on Octave, so you should really consider what you need by way of calculation. Numpy probably has most if not all of the functions you’ll need.
>>>> Best of luck
>>>> S
>>>> Sent from my iPad
>>>>>> On Jan 19, 2021, at 11:13 AM, Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute> wrote:
>>>>> Thank you very much Salvatore,
>>>>> There is no Octave code base that I know of, but this is a very good direction.
>>>>> -Michelle W5NYV
>>>>>> On Sun, Jan 17, 2021 at 8:31 AM Salvatore Lionetti via Ground-Station <ground-station at lists.openresearch.institute> wrote:
>>>>>> Hi guys,
>>>>>> I'm sorry but I've started yesterday to work on this topic.
>>>>>> I've made the spreadsheet available on my personal Nextcloud web instance:
>>>>>> https://cumlaborare.strangled.net/s/Ng5H3RmmZP8HzNE
>>>>>> By this way:
>>>>>> * multiple people can collaborate on the same document, at the same moment.
>>>>>> * comments are allowed,
>>>>>> * versioning is in force.
>>>>>> I've setup no password for now, but content can be recovered from a previous version very easily. (similar to Wikipedia)
>>>>>> In the meanwhile I've verified that Jupyter can also use Octave interpreter, giving us the possibility to have a single code base.
>>>>>> Is there a (also partial) Octave code base to reuse?
>>>>>> Have a good day
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20210120/6b66bdbe/attachment-0001.html>
