[Ground-station] Link budget
Salvatore Lionetti
salvatorelionetti at gmail.com
Mon Feb 8 16:26:05 PST 2021
Hi,
Thanks all for the discussion.
I'm convinced that for ORI the web approach is, where possible, the way to
use.
I ported the propa library <https://logiciels.cnes.fr/en/content/propa>
into a public Jupyter notebook
<https://www.kaggle.com/salvatorelionetti/propa-py-test>
To use it, once opened the notebook, take an empty cell at the bottom and
type something similar to:
>>propa_lib.rain_intensity(46.22,6.12,0.01)
Please look at propa.h inside the notebook for further methods and
parameter meanings.
Regarding the spreadsheet I admire the Excel possibility to have lot of
data (No secrets!) under the mouse.
My intention is hence to keep this spirit, having if possible a graphical
web tool similar to Node Red <https://nodered.org/>, better if already
integrated in Python.
For model scenario / models comparison I have some idea, hoping to plant
them during the way.So I'm here to listen your opinion on this.
I know that in the meanwhile the Link was already debugged and worked on,
but my active spare time (as many of you) is not what I would like.
Have a good day
On Thu, Jan 21, 2021 at 8:09 PM Bruce Perens via Ground-Station
> Crystal has some "shards" (user-contributed packages) that would interest
> us, which I have listed below.
> My own preference is to do all UI via web applications, since I have had
> such a great experience making UIs and two-way voice applications work on
> browsers. In general iOS trails the APIs implemented on everything else,
> with that exception you get great portability across operating systems
> without having to use somebody's portability layer like wxWidgets and build
> binaries on every platform. My apps generally live on devices or servers
> and talk to everything.
> Although I write significant amounts of Javascript, I try to keep as much
> work as possible on the server, since Javascript is sort of wild-west.
> Documentation of packages and utilities - even ones that everybody uses -
> is poor to nonexistent. Packages don't in general document whether they
> work in the browser or just in Node.
> For plotting, I like best to draw on the web canvas. The API includes the
> good stuff we learned from the Postscript Red Book, a 2D paradigm with easy
> matrix transforms (and I don't do DSP, so this is all I ever have to do
> with matrix math). The PDF of the Red Book and its successors is on the web
> for free these days, and is still the best place to learn the paradigm.
> - alea <https://github.com/nin93/alea> - Repeatable sampling, CDF and
> other utilities to work with probability distributions
> - ishi <https://github.com/toddsundsted/ishi> - Graph plotting package
> with a small API and sensible defaults powered by gnuplot
> - linalg <https://github.com/konovod/linalg> - Linear algebra library
> inspired by MATLAB and SciPy.linalg
> - num.cr <https://github.com/crystal-data/num.cr> - Numerical
> computing library supporting N-Dimensional data
> - predict.cr <https://github.com/RX14/predict.cr> - Satellite
> prediction library using the sgp4 model
> - quartz <https://github.com/RomainFranceschini/quartz> - Modeling and
> simulation framework
> On Thu, Jan 21, 2021 at 10:47 AM Juno Woods <juno at openlunar.org> wrote:
>> Ruby syntax is so nice. The challenge with using it for
>> science/engineering has always been the lack of a killer plotting app. I'd
>> love to see Crystal change that, but I worked on this for years with Ruby
>> (see: SciRuby) without much success. It would really require a large
>> organization to throw its weight behind developing such a tool, IMHO.
>> This same thing is an issue for other languages people have suggested as
>> well. It's difficult to duplicate the plotting functionalities of Python
>> and Matlab/Octave.
>> I'm +1 for Python over Octave. Choice of language helps determine the
>> engineering culture we draw from as well, and Python ties us a bit more to
>> the larger software engineering community.
>> Juno
>> On Wed, Jan 20, 2021 at 12:53 PM Bruce Perens via Ground-Station
>>> While you are looking at advanced languages, here is a piece I wrote on
>>> Crystal a while back. It's the logical successor to Ruby, which IMO was
>>> advanced beyond Python. But there is a cost to being on the bleeding edge.
>>> https://perens.com/2020/06/28/building-a-startup-with-crystal-and-lucky/
>>> On Wed, Jan 20, 2021 at 12:39 PM Thomas Savarino via Ground-Station
>>>> I’d like to hear more about your Golang work and why you use that.
>>>> S
>>>> Sent from my iPhone
>>>> On Jan 20, 2021, at 12:32 PM, Robert McGwier via Ground-Station
>>>> I want to strongly support python for the work. I do simulations in
>>>> Matlab and some architecture design work and then I use python and I'm
>>>> moving into Golang for compiled code.
>>>> Bob
>>>> Dr. Robert W McGwier, Ph.D.
>>>> Adjunct Faculty, Virginia Tech
>>>> ARDC Member of Board
>>>> ARS: N4HY
>>>> ARRL, AMSAT, AAVSO, TAPR, SkyHub
>>>> On Tue, Jan 19, 2021, 4:07 PM Michelle Thompson via Ground-Station
>>>>> Thank you Thomas and Alan for the valuable input.
>>>>> I have a soft spot in my heart for Octave and MATLAB, and am used to
>>>>> having them be a significant part of technical work like this. If Python
>>>>> can do the job, and it's the preferred expression for the work, then by all
>>>>> means let's proceed.
>>>>> -Michelle W5NYV
>>>>> On Tue, Jan 19, 2021 at 2:03 PM Alan Rich <arich127 at gmail.com> wrote:
>>>>>> Hi All ,
>>>>>> My apologies for being really late / absent to respond to lots of the
>>>>>> emails on this subject.
>>>>>> I think I was the one that unfortunately dragged Octave into the
>>>>>> discussion. The main reason was that I am not an experienced python person
>>>>>> (yet) but I have contributed in the past to some Matlab utilities for RF
>>>>>> work that were converted to executables in the end. Matlab isn't open
>>>>>> source, but Octave is, and it was one of the original open engineering
>>>>>> tools. It's been around for 20 plus years and has good community support. I
>>>>>> was thinking that a link budget and propagation "Toolbox" for Octave might
>>>>>> be a nice thing to have for the community.
>>>>>> Given that python, numpy, scipy.. have really become the open source
>>>>>> baseline, I'm sure that this is absolutely the right way to go for a
>>>>>> mission application/planning tool. I apologize for the distraction.
>>>>>> I'll experiment a bit over in Matlab/Octave in the background to see
>>>>>> if a set of .m files or functions can be built up to support future work.
>>>>>> Link budgets , Bus power budgets (and antenna pointing requirements)
>>>>>> are so important. Everything else ( throughput and BER/SER/PER) falls out
>>>>>> of them.
>>>>>> Cheers!
>>>>>> Alan
>>>>>> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virus-free.
>>>>>> www.avg.com
>>>>>> <#m_4534719704617135228_m_-2462185537550317974_m_5021025678534474979_m_-7217812766232080695_m_6488736157870010448_m_9189044632356751745_m_3502320734441759451_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>>> On Tue, Jan 19, 2021 at 3:56 PM Thomas Savarino <
>>>>>> thomas.savarino at mac.com> wrote:
>>>>>>> I understand that you don’t want any help with this, but I can’t
>>>>>>> resist mentioning that you’d probably be better off doing everything in
>>>>>>> python and avoiding the dependence on Octave, so you should really consider
>>>>>>> what you need by way of calculation. Numpy probably has most if not all of
>>>>>>> the functions you’ll need.
>>>>>>> Best of luck
>>>>>>> S
>>>>>>> Sent from my iPad
>>>>>>> On Jan 19, 2021, at 11:13 AM, Michelle Thompson via Ground-Station
>>>>>>> Thank you very much Salvatore,
>>>>>>> There is no Octave code base that I know of, but this is a very good
>>>>>>> direction.
>>>>>>> -Michelle W5NYV
>>>>>>> On Sun, Jan 17, 2021 at 8:31 AM Salvatore Lionetti via
>>>>>>> Ground-Station <ground-station at lists.openresearch.institute> wrote:
>>>>>>>> Hi guys,
>>>>>>>> I'm sorry but I've started yesterday to work on this topic.
>>>>>>>> I've made the spreadsheet available on my personal Nextcloud web
>>>>>>>> instance:
>>>>>>>> https://cumlaborare.strangled.net/s/Ng5H3RmmZP8HzNE
>>>>>>>> By this way:
>>>>>>>> * multiple people can collaborate on the same document, at the same
>>>>>>>> moment.
>>>>>>>> * comments are allowed,
>>>>>>>> * versioning is in force.
>>>>>>>> I've setup no password for now, but content can be recovered from a
>>>>>>>> previous version very easily. (similar to Wikipedia)
>>>>>>>> In the meanwhile I've verified that Jupyter can also use Octave
>>>>>>>> interpreter, giving us the possibility to have a single code base.
>>>>>>>> Is there a (also partial) Octave code base to reuse?
>>>>>>>> Have a good day
>>>>>> www.avg.com
>>>>>> <#m_4534719704617135228_m_-2462185537550317974_m_5021025678534474979_m_-7217812766232080695_m_6488736157870010448_m_9189044632356751745_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>> Bruce Perens - CEO at stealth startup. I'll tell you what it is
>>> eventually :-)
> Bruce Perens - CEO at stealth startup. I'll tell you what it is eventually
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20210209/40ca0b1f/attachment-0001.html>
