[Ground-station] 3DS model request
Thomas Savarino
thomas.savarino at me.com
Fri Oct 23 17:59:12 PDT 2020
Here they are
TomS
> On Oct 23, 2020, at 5:41 PM, Douglas Quagliana via Ground-Station <ground-station at lists.openresearch.institute> wrote:
> All,
> NASA has a 1U and 2U 3DS cubesat models on their 3DS webpage.
> You might be able to do whatever the 3DS equivalent of "edit-copy-edit-paste-edit-paste" is and turn the 2U into a 6U.
> That's probably easier than starting from scratch. Check out the first two models under "#" on this page:
> https://nasa3d.arc.nasa.gov/models <https://nasa3d.arc.nasa.gov/models>
> 73,
> Douglas KA2UPW/5
> On Fri, Oct 23, 2020 at 12:31 PM Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute> wrote:
> Achim Vollhardt is looking for a .3DS model of a 6U spacecraft.
> This will go into the GMAT mission planning for the orbits we're targeting.
> If you know how to produce a .3DS model and have some time, then I will get you the specifications.
> The work products are not just useful in terms of orbit planning and modeling with GMAT, but also include animated visualizations that resonate with our audience and potential operators.
> If you have been waiting for a reason to get into 3d modeling and creation, this is a very achievable first project.
> I'm available over the weekend to help get this accomplished! Drop me a line directly or reply here.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20201023/2946c37b/attachment-0003.html>
Type: application/octet-stream
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20201023/2946c37b/attachment-0002.obj>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20201023/2946c37b/attachment-0004.html>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20201023/2946c37b/attachment-0003.obj>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20201023/2946c37b/attachment-0005.html>
