    Robert McGwier
    rwmcgwier at gmail.com
    Sun Nov  1 18:19:06 PST 2020
It is a real shame we can't purchase high quality FM bandstop filters. I
have purchased some I hoped would work and they attenuated the FM band and
much more. Next, as you well know, lots of people pretend every piece of
crap they hook to the antenna terminal is a 50 Ohm resistive load at all
frequencies from DC to light and doesn't crash the front end filtering etc
with their decidedly not 50 Ohm resistive loads.
 Cheers,
Bob
On Sun, Nov 1, 2020, 10:42 AM KENT BRITAIN <wa5vjb at flash.net> wrote:
> Hi Bob
> I covered this topic at my Def Con talk on the Care and Feeding of SDR's.
> A bit harder to get these days, but Radio Shack and several others sell an
> FM Band Notch filter   In with the rest of the TV accessories.   Very
> little
> loss outside 80-120 MHz.
> These days if you put up a broad band antenna in a urban area, about
> 2/3rds of the RF energy it picks up will be in the FM Broadcast band.
> (Quite a bit of local variation in that 2/3rd's)
> Amazing how many guys though they could eliminate the FM band overload
> but just telling the SDR to ignore 88-108 MHz in the software.
> 73 Kent WA5VJB
> On Sunday, November 1, 2020, 10:20:36 AM CST, Robert McGwier via
> A single strong FM transmitter anywhere near will collapse the front end.
> A FM bandstop filter also degrades 2 meter low end and has insertion loss
> that harms the sensitivity further.
> RTLSDR is great but you get what you pay for
> Bob
> On Sat, Oct 31, 2020, 2:10 PM Phil Karn via Ground-Station
> On 10/31/20 11:10 AM, Douglas Quagliana wrote:
> > Hi Phil,
> >    Please let me know when the code is available. I would like to try
> > getting it to run off an RTLSDR dongle and try to have it identify the
> > callsigns of the repeaters that it receives.
> > 73,
> > Douglas KA2UPW/5
> In principle I could use the RTL-SDR, but I haven't actually used it
> myself yet. It has a rather low dynamic range, so strong local repeaters
> could blank weaker signals on other channels within its bandwidth.
> Getting the most out it will probably require a lot of work on a good AGC.
> My favorite SDR used to be the AMSAT-UK Funcube dongle, but it has a
> very limited bandwidth (192 kHz). I'm now using the Airspy R2, which has
> a 10 MHz bandwidth and 12-bit sampling. This is enough to easily cover
> the entire 2m band. It can cover most of the 440-450 segment, but the
> actual coverage of SDR is a little less than 10 MHz because of
> anti-alias filtering ahead of the A/D. But it can easily cover the 5 MHz
> half of whatever segment used in your local area for repeater outputs
> (i.e., either 440-445 or 445-450).
> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20201101/5574d5bb/attachment.html>
