[Ground-station] Please Donate to Help Continue Microsatellite Electric Thruster Creation
Bruce Perens
bruce at perens.com
Thu Jun 18 20:06:21 PDT 2020
Please Help Fund the Creation of Thrusters for Cubesats and PocketQube
Satellites
Donate at GoFundMe <https://gf.me/u/x9vnv2>
>From Bruce Perens K6BP: <https://perens.com/>
Michael Bretti is designing electric thrusters so that Amateur and
Educational microsatellites can maintain or change their orbits. Some of
his designs are small enough to work on a PocketQube
<https://en.wikipedia.org/wiki/PocketQube>, a satellite literally so small
that it fits in your pocket.
Michael has so far created several working thruster designs, as Open Source
Hardware. Below Michael's photo is his gridded pulsed plasma thruster
firing in a vacuum chamber he's put together in his home. And the photo
below that is another of his thruster designs being readied to fly as part
of the GENESIS N and L satellites
<http://perens.com/static/AppliedIon/AMSAT-EA-Newsletter_11-2019.pdf>.
That's his thruster between the two measuring tapes.
Michael calls his project Applied Ion Systems, and you can follow his work
at @Applied_Ion <https://twitter.com/Applied_Ion> on Twitter.
I've been following Michael's work for about a year, and this is a
tremendously important project for Amateur and Educational satellites. It
will provide them with thrusters that are easily affordable on their slim
budgets, and allow them to maintain or change their orbits like the big
boys!
To test the thrusters, he uses a vacuum chamber that duplicates the *hard
vacuum* of low-earth orbit. Vacuum is hard, and hard vacuum is harder, and
hardly cheap. Due to his shoestring budget of literally pocket money - he
has no significant funding and works on his own time - Michael's work has
been plagued by failures of his roughing pump
<https://en.wikipedia.org/wiki/Roughing_pump>. That's a pump which creates
a medium vacuum and supports another pump that provides the space-quality
vacuum. He bought and attempted to rebuild a worn-out roughing pump - all
that he could afford - but this effort failed. Michael can't go on with
testing until he gets a reliable roughing pump. That would allow him to
move forward confidently in creating thrusters for our satellites. Michael
would like to buy an Edwards RV12, which is available for no more than
$4200 Please help to fund the new pump.
With the ability to achieve a space-quality vacuum again, Michael will
proceed with new designs. Not every one succeeds, because space is hard,
but enough do. You'll be able to watch his efforts and - soon enough -
perhaps you'll communicate through some of the satellites he supports.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200618/eeceeafe/attachment.html>
