[Ground-station] Planar antennas
Wed Feb 5 16:33:20 PST 2020
Do you see any large metamaterial lens out front?If so it would be nearly as thick as it is wide.
Very different technology.
On Wednesday, February 5, 2020, 5:25:39 PM CST, Daniel Zeleznikar <daniel.zeleznikar at gmail.com> wrote:
Sounds similar to this tech... is it the same?https://www.thinkom.com/technology/
On Wed, Feb 5, 2020 at 2:59 PM KENT BRITAIN via Ground-Station <ground-station at lists.openresearch.institute> wrote:
A Concept drawing.
Much easier ways of doing it and it completely leaves outthe logic systems necessary to control it.
Kent WA5VJB
On Wednesday, February 5, 2020, 3:39:17 PM CST, KC9SGV via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Maybe this is old news...
https://www.mq.edu.au/__data/assets/pdf_file/0011/556805/MQ-2015016-Planar-High-Gain-Antennas-with-Variable-Beam-Directions.pdf
Bernard,
KC9SGV
Sent from my iPad
Dan Zeleznikar
(216) 233-6232
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200206/6cfb95ab/attachment.html>
