[Ground-station] FO-98 OrigamiSat-1 5.84 GHz downlink
Mike Seguin
Thu May 30 04:14:45 PDT 2019
I apologize for the short notice.....
The OrigamiSat-1 Team will remotely activate the 5.84 GHz downlink on
FO-98 for four upcoming passes over the Northeastern US. The times
listed are based on my QTH here in Vermont at FN34jm.
5.84GHz transmission from OrigamiSat-1 (FO-98)
Day Objects AOS (U) LOS Period maxEl AZ
31.05.2019 FO-98 01:29 01:39 10 59 157 - 351
31.05.2019 FO-98 14:30 14:40 10 59 015 - 188
01.06.2019 FO-98 01:10 01:19 09 35 144 - 357
01.06.2019 FO-98 14:11 14:20 09 37 022 - 176
The latest kep data is here:
FO-98
1 43933U 19003B 19150.08119722 .00000607 00000-0 29789-4 0 9993
2 43933 97.2825 208.2757 0018888 149.0302 270.2283 15.21599516 20077
I manually updated my nasa.all file in SatPC32 to use these.
5.8GHz specifications:
http://www.origami.titech.ac.jp/archives/722
http://www.origami.titech.ac.jp/wp/wp-content/uploads/2019/01/OP-S1-0117_5R8GDownLinkDataFormat_20190111b.pdf
If you have 5.8 GHz receive capability and are in the Eastern US, please
consider trying to detect the downlink.
The equipment I am using is the same that I used to successfully detect
NIWAKA in 2012 on 5.84 GHz.
DEMI 5.760 GHz transverter with a 2' dish and Directive Systems linear
feed (Horizontal). I also have a DEMI preamp inline. The IF I'll be
using is a Funcube Dongle Pro+ set for 224 MHz. This equipment is my
terrestrial 5.760 GHz system which works quite well out of band at 5.84 GHz.
Please report any success here and you can also use the reception report
on their website. The OrigamiSat-1 team is also on Twitter. @OrigamiSat1
Mike, N1JEZ
