[Ground-station] output of dvbs2_rx app
Ron Economos
w6rz at comcast.net
Tue Mar 5 17:13:11 PST 2019
It's just an artifact of the GNU Radio scheduler and buffering. The end
of the bitstream doesn't get flushed out. To check for bit errors, I use:
cmp -l thefuryclip.ts decoded.ts
Also, you can suppress that Gtk-Message with:
sudo apt install libcanberra-gtk-module
Ron
On 3/5/19 16:50, Christopher Howard via Ground-Station wrote:
> Hi, this is likely a very elementary question, but I was playing around
> with the dvbs2_rx test app, and was just wondering why the output file
> comes out a different size and md5sum than the input file. If I set the
> noise default to 0, this does not change the output md5sum. Both files
> play just fine and look the same when played. The output ends up
> smaller by about 60000 bytes.
> $ gnuradio-companion --version
> Gtk-Message: Failed to load module "canberra-gtk-module"
> GNU Radio Companion 3.7.10
> OS: Debian GNU/Linux 9.8 (stretch) x86_64
> Model: 2347B46 ThinkPad T430
> Kernel: 4.9.0-8-amd64
> Uptime: 12 days, 6 hours, 42 minutes
> Packages: 2178
> Shell: bash 4.4.12
> Resolution: 1600x900, 1280x1024
> DE: GNOME
> WM: GNOME Shell
> WM Theme: Adwaita
> Theme: Adwaita [GTK2/3]
> Icons: Adwaita [GTK2/3]
> Terminal: gnome-terminal
> CPU: Intel i5-3320M (4) @ 3.3GHz
> GPU: Intel Integrated Graphics
> Memory: 3867MB / 7689MB
