[Ground-station] output of dvbs2_rx app
Christopher Howard
christopher at alaskasi.com
Tue Mar 5 16:50:11 PST 2019
Hi, this is likely a very elementary question, but I was playing around
with the dvbs2_rx test app, and was just wondering why the output file
comes out a different size and md5sum than the input file. If I set the
noise default to 0, this does not change the output md5sum. Both files
play just fine and look the same when played. The output ends up
smaller by about 60000 bytes.
$ gnuradio-companion --version
Gtk-Message: Failed to load module "canberra-gtk-module"
GNU Radio Companion 3.7.10
OS: Debian GNU/Linux 9.8 (stretch) x86_64
Model: 2347B46 ThinkPad T430
Kernel: 4.9.0-8-amd64
Uptime: 12 days, 6 hours, 42 minutes
Packages: 2178
Shell: bash 4.4.12
Resolution: 1600x900, 1280x1024
DE: GNOME
WM: GNOME Shell
WM Theme: Adwaita
Theme: Adwaita [GTK2/3]
Icons: Adwaita [GTK2/3]
Terminal: gnome-terminal
CPU: Intel i5-3320M (4) @ 3.3GHz
GPU: Intel Integrated Graphics
Memory: 3867MB / 7689MB
