[Ground-station] Upcoming channelizer test opportunity
Wed Jun 26 07:34:56 PDT 2019
I have apparently rescheduled the entire contest calendar. Who knew I had
such power. Thanks for the correction!
I have a video I made one year and several photo sets of tuneups from San
Diego Microwave Group. I’ll try and post them in a bit. It’s quite the
sight to see all the rigs lined up.
On Wed, Jun 26, 2019 at 06:23 Drew Arnett <arnett.drew at gmail.com> wrote:
> Interesting idea. Put a RSSI on multiple channels and let several do
> EIRP testing at the same time. And converse for MDS testing. (Run
> two of these against each other first to try before a tuneup picnic?)
> And that's the ARRL 10 and Up contest in August/September, not the
> SBMS 2 and Up contest in May, that folks do the preparation parties
> for. (But, I'm sure 100% will figure that out no problem.)
> Drew
> kb9fko
> On Wed, Jun 26, 2019 at 11:01 AM Michelle Thompson via Ground-Station
> > Later in the summer we usually have at least one tuning party for the
> 2GHz and Up amateur radio contest. That would be a good opportunity to try
> on air testing with this channelizer at microwave.
> > The way the test works is there is a transceiver just outside of near
> field range. Minimum discernible signal and output gain are the two numbers
> obtained. For the test it’s usually done serially, everyone using same
> frequency, one at a time.
> > Channelizer wouldn’t replace that setup, but the event has lots of
> radios all in one place on all kinds of amateur Microwave bands so we
> should try and take advantage of it, assuming the channelizer will reliably
> work by then, and that we can put an SDR up on a pole and at least receive
> with it. 5GHz and 10GHz are straightforward. Above that, we need more RF RX
> gear.
> > There is another similar event up in Los Angeles, around the same time.
> > So, if you have a local Microwave Group that does something similar, and
> want to test a channelizer, let me know. At the very least would be a fun
> paper for Microwave Update or GNU Radio Conference. And, an effective
> amateur radio demo of polyphase channelizers in practice.
> > -mdt
> > -Michelle W5NYV
> > "Potestatem obscuri lateris nescis."
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190626/fd7908b5/attachment.html>
