[Ground-station] 1269 MHz
Fri Sep 7 11:57:00 PDT 2018
I'm setting up vendor services for Sierra Charlie (that's our room at
GRCon).
Derek worked it out so that Open Research Institute can be a sponsor, which
is the only way to allow advertising. We're good there.
I'm filling out the forms with Nevada for a one-time sales tax license
filing, as the event sales promoter. That way it's all legal.
So, if this works, and anyone besides me and Kent need to sell something at
GRCon, let me know *now* so I can put you on the list.
And report taxes, if any sales.
On Fri, Sep 7, 2018 at 9:10 AM Michelle Thompson <
> Consider the Sierra C Block Party room as a place you can set up a
> sale/demo, if you like.
> On Fri, Sep 7, 2018 at 8:57 AM KENT BRITAIN <wa5vjb at flash.net> wrote:
>> Probably
>> *From:* Michelle Thompson <mountain.michelle at gmail.com>
>> *To:* KENT BRITAIN <wa5vjb at flash.net>
>> *Cc:* Michelle Thompson via Ground-Station
>> <ground-station at lists.openresearch.institute>
>> *Sent:* Friday, September 7, 2018 10:53 AM
>> *Subject:* Re: [Ground-station] 1269 MHz
>> Can you bring any of these to GNU Radio Conference?
>> On Fri, Sep 7, 2018 at 7:30 AM Ground-Station
>> Certainly sounds like there is interest.
>> I only have a few prototypes at the moment and they are low in frequency.
>> I need
>> to spend some time on the antenna range. I think there is a dB or two
>> hiding in there.
>> Back to work, Kent G8EMY/W5
>> *From:* Frank Brickle <brickle at pobox.com>
>> *To:* aardvark at saintaardvarkthecarpeted.com
>> *Cc:* KENT BRITAIN <wa5vjb at flash.net>; Michelle Thompson via
>> Ground-Station <ground-station at lists.openresearch.institute>
>> *Sent:* Friday, September 7, 2018 9:16 AM
>> In fact I have two Arrows, so I'll take two extensions.
>> 73
>> Frank
>> AB2KT/VE7
>> On Fri, Sep 7, 2018 at 7:09 AM Ground-Station
>> Ground-Station wrote:
>> > OK, this falls sort of under marketing research.
>> > About how many AMSAT lads have an Arrow antenna?
>> > How many would be interested in adding 1269 MHz to them for about $50?
>> > I have prototype 11 element Yagi's designed to clip on the boom of
>> theexisting Arrow antennas. Trying to get an idea of how many to run.
>> > 73 Kent WA5VJB
>> Count me in!
>> Hugh Brown
>> http://saintaardvarkthecarpeted.com
>> Tell me, what is it you plan to do with your one wild and precious life?
>> -- Mary Oliver
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180907/37f37018/attachment.html>
