[Ground-station] 1269 MHz
Fri Sep 7 09:10:24 PDT 2018
Consider the Sierra C Block Party room as a place you can set up a
sale/demo, if you like.
On Fri, Sep 7, 2018 at 8:57 AM KENT BRITAIN <wa5vjb at flash.net> wrote:
> Probably
> *From:* Michelle Thompson <mountain.michelle at gmail.com>
> *To:* KENT BRITAIN <wa5vjb at flash.net>
> *Cc:* Michelle Thompson via Ground-Station
> *Sent:* Friday, September 7, 2018 10:53 AM
> *Subject:* Re: [Ground-station] 1269 MHz
> Can you bring any of these to GNU Radio Conference?
> On Fri, Sep 7, 2018 at 7:30 AM Ground-Station
> Certainly sounds like there is interest.
> I only have a few prototypes at the moment and they are low in frequency.
> I need
> to spend some time on the antenna range. I think there is a dB or two
> hiding in there.
> Back to work, Kent G8EMY/W5
> *From:* Frank Brickle <brickle at pobox.com>
> *To:* aardvark at saintaardvarkthecarpeted.com
> *Cc:* KENT BRITAIN <wa5vjb at flash.net>; Michelle Thompson via
> Ground-Station <ground-station at lists.openresearch.institute>
> *Sent:* Friday, September 7, 2018 9:16 AM
> In fact I have two Arrows, so I'll take two extensions.
> 73
> Frank
> AB2KT/VE7
> On Fri, Sep 7, 2018 at 7:09 AM Ground-Station
> Ground-Station wrote:
> > OK, this falls sort of under marketing research.
> > About how many AMSAT lads have an Arrow antenna?
> > How many would be interested in adding 1269 MHz to them for about $50?
> > I have prototype 11 element Yagi's designed to clip on the boom of
> theexisting Arrow antennas. Trying to get an idea of how many to run.
> > 73 Kent WA5VJB
> Count me in!
> Hugh Brown
> http://saintaardvarkthecarpeted.com
> Tell me, what is it you plan to do with your one wild and precious life?
> -- Mary Oliver
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180907/cbb08070/attachment.html>
